I have a 40MB JVC HDD (Model: JDE3848V10-1) with a 44 pin male connector from old Toshiba Laptop that I used 30+ years ago.
I'd like to connect the HDD to my current PC to see if there is anything interesting on the drive. (I realize it might be dead, but it was working when I removed it years ago.)
When I look it up online, I can find references to it being an IDE interface, but the connector is longer (it's ~2.5") and the pins are spaced further apart than on the IDE connectors used today.
In the photo below, you can see the 44 pin male connector on the HDD, and a current 44 pin IDE female connector (from a Sabrent IDE/SATA to USB converter) above it.
Any idea what kind of cable/converter I need to use to connect it to a current PC?
Thanks!
Thanks!
