Coder
- Joined
- Apr 16, 2023
- Messages
- 84
Hello everyone. I have a Sharp PC-7200 that when booting complains of "Invalid configuration information" and says to "Strike F1 to continue". When I got it, the original CMOS battery was dead, as you might expect. I've replaced it with the same voltage Ni-MH battery, and it now stores settings and keeps time. But on boot, it still complains of "Invalid configuration information". You can press Alt+Ctrl+Setup to get into the BIOS configuration, but not all BIOS values are exposed to the user, and I suspect something that's not exposed has become corrupt. I have some questions that I hope someone here can answer with some sort of authority:
- Shouldn't the default CMOS configuration get loaded if the CMOS battery is unattached? It definitely was while I changed the battery. It was completely detached for at least a few minutes.
- If the default CMOS configuration was supposed to get loaded but it's still complaining of it being invalid, would that indicate bad CMOS RAM? Or could it be that the DIP switches on the back are in an invalid state?
- Is there a way to set the configuration other than through the built in setup utility? I've heard there is a universal configuration disk, but I can't find any information on it now. Would it work on a computer as non-standard as these Sharps? Would it hurt anything to try?
- If the CMOS RAM ends up being bad, can it be replaced? Is it possible that this could be a bad BIOS ROM?
- Right now, everything seems to work except it will neither boot off the hard drive nor detect it when booting from the floppy drive and using FDISK. But on startup, the drive spins up and initializes and the HDD LED lights momentarily after the Floppy one does during its initial checks.
