6805 and 6808 are mostly microcontrollers for embedded applications. They usually have lots of embedded flash and some RAM and special IO. They are similar to AVR with many memory/IO options so perhaps they are numerous, but minor branches of 6800 Family tree.
683xx are mostly embedded computers. 68328 is well-known because it is in Palm Pilot. 68332/68336/68340/68376 are mostly embedded engine controllers. 68360 is often an IO companion to 68040. I’ve reverse engineered a SBC based on 68302 and ported CPM68K to it. Originally it was a controller for network server.
https://forum.vcfed.org/index.php?threads/porting-cp-m-68k-to-a-recycled-board.61681/#post-746253
P90CE201 is new to me but I ported CPM68K to it 2-3 years ago. I don’t know whether or what commercial computers were based on it. https://www.retrobrewcomputers.org/doku.php?id=builderpages:plasmo:p90mb:p90mb_r1
I think you should remove Z800 so the family line goes directly from Z80 to Z280. Tilmann Reh famously designed CPU280 for hobbyists based on Z280.
I collect CPU and have several tubes of NS32008 but I don’t know any computers based on 32008.
Bill
Thanks, I will remove the 6805 and 6808. The 68328 is a tricky one, it's a microcontroller but was used in some popular early hand-helds. I will include it because Palm Pilots are important devices in computing history.
The P90CE201 seems more like a CPU with some built in peripherals than a microcontroller, especially as it doesn't have RAM or ROM. The line is somewhat blurred. Many modern CPUs have peripherals - memory controllers, PCIe controllers, even USB controllers and SMBUS for mobile parts. I think though if it wasn't used to any known computers I'll leave it off for now.
I'll remove the Z800.
