It's got a 233MhZ CPU in a PCI/ISA board that has both AT and ATX power connectors, and SIMM and DIMM memory slots. I've installed a couple of Lian-Li Mobile Drive Racks so I can swap hard drives in a snap and I have a stack of drives with various OSes on them. Normally I run WIN98SE DOS on it because it offers FAT-32 hard drive availability. But I also have nearly all DOS versions on floppies and both 5.25" and 3.5" floppy drives in the machine as well.Stone, I'm curious to know what your tweener is.
There's a number of options you could try using UNBD to transfer the files .Stone, I'm curious to know what your tweener is. But good question. Is there a way for Windows computers to see Dos computers on the network?
One is MSs own dos network client:
http://www.windowsnetworking.com/j_helmig/dosclien.htm
http://www.compmiscellanea.com/en/network-setup-in-dos-microsoft-network-client.htm
http://msdn.microsoft.com/en-us/library/cc750214.aspx
To add server capability to the dos client, using WG1049.EXE, refer to:
http://www.windowsnetworking.com/j_helmig/dosservr.htm
Other usefull reference pages:
http://www.freedos.org/wiki/index.php/Networking_FreeDOS_complete
http://www.jacco2.dds.nl/samba/dos.html
Strip the network component from wfw 3.11
http://users.telenet.be/mydotcom/library/network/wfwdos.htm
XP can support NetBeui http://californiasoftwaresystems.com/ts/netbeui-for-windows-xp/ to keep the memory overheads down compared to using a TCP/IP in the MS Dos Client.
You'll have to disable the settings Heather mentioned earlier in Windows 7/8x though I'd imagine if going the tcp/ip route withe dos client.
Seems you might be able to add neteui to Widows 7 Post #62 http://www.sevenforums.com/network-...ile-share-between-windows-7-windows-xp-7.html Running in netbeui in xp mode is probably a better option though.
No, not at all... I wish.That is impressive! I guess you have ALL of the bases covered.
I have gottenIt's got a USB card but so far I've been unable to get anything to reliably recognise the USB sticks from DOS.
I haven't had success with that.
I have gotten
USBASPI.SYS
and
DI1000DD.SYS
to support a flash driver under DOS.
The catch is you have to reboot to change devices and it slows down boot significantly
As smeezekitty pointed out you need both USBASPI.SYS and DI1000DD.SYS. I found this to be the best explanation:I haven't had success with that.
it should be noted that this driver will only map mass storage devices like external hard disks, cd- roms, cd-rw, dvd-rom, zip, jaz, ls-120, and flash memory to ASPI devices. Then you need an elusive "ASPI mass storage driver" to map HDs and flash disks it to a drive letter in DOS. This one goes by the name "di1000dd.sys", commonly referred to as the "Motto Hairu USB Driver". Don't ask why, it's called that, I don't know.
Yes. USBASPI.SYS gives this:If you step through your config.sys file do you see any errors when those two drivers are loaded?
Sorry, my bad...OK, got it to work. I reseated the USB card after cleaning the contacts and now it's fine with flash drives that are ≤ 2GB. I guess DOS isn't gonna recognize a drive over 2GB unless it's partitioned.
Thanks to the UNBD disk, I was able to easily upgrade my Gateway 2000 system drive from 1 GB to 1.5 GB using Ghost 2003. After installing the new drive, I restored the image from the old C:drive (1 GB) and Ghost automatically expanded the drive to 1.5 GB on the system drive! I was also able to get all 128 MB of RAM working (with new ram sticks), so there is no need for me to do a clean install of Windows 95 after all. Finally!
