I have a 386-era motherboard (VIP M319P1 TAM/40-P1) which came with an Am386DX-40 processor, 64 K of L2 Cache (speed is 20 ns), and has eight ISA expansion slots on it. There is also 4 MB of main memory (speed is 70 ns).
There are 3 crystal oscillators on the motherboard that I can see:
KTS38 (small, barrel shaped)
14.31818 TQE (rectangular, silver)
KOYO KCO-110s 80.000 MHz 91-22 (larger, rectangular, silver)
I'm pretty sure the third one is the main system clock, and the CPU divides it by 2 (internally) to get 40 MHz.
I can't figure out what the other two clocks are for, can anyone help me figure this out?
Also, there is a jumper on the motherboard, "Bus Speed Select" that can be set to either "ATCLK/8" or "ATCLK/6". I'm pretty sure this is to set the ISA Bus speed, which ideally should be at 8.33 MHz I believe. But it's not clear what clock signal this jumper is dividing. Any help with this also would be greatly appreciated!
