supersPORT
Is it possible for me to replace my supersport's floppy with a harddrive, one thats not the same size as the standard HD, something like a 60 gig seagate i have laying around?
Well, you can't use the floppy controller cable with a hard drive. Pin-outs are totally different. It would physically fit but you would have to build a custom "ide chain" cable, where one drive is the master and the other slave. I have no idea what kind of cable goes from the ide controller to the drive. If it's one of those white totally flat ribbon cables, making a "chain" cable would be a challenge, at least to me it would. Those connectors where you have to push the ribbon cable into a slot can't stand a lot of reuse (putting cable in and out). And, .... finally, hard drives take lots of power, the on-board fuses would likely give up the ghost under the load.
befor you speak again, go on that site you gave me befor atake a look at the pics that show what it lookslike inside, if you know nothing about the computer i'm talking about you should not try to tell me what should maybe might kinda sorrta on some things be there.Oh, you mean there isn't a hard drive in there already? In that case, it is much easier. Still somewhat complicated. Are there those four position power connectors available or do the drives get their power thru the regular cable? It's very common to have the hard drive on the bottom with only one floppy drive above that. Of course, if designed that way, comes with a fancy mounting bracket to hold both items.
Cool, thanks, I'll look online to try and find the right type, Your the first person on 3 sites to give me Actual, information, most of the other places just have jabbering idiots about "they never made laptops in the 80's you trollI've never seen the guts of a floppy-only SS before, but I believe that the short answer in no, it probably won't work. The 8088-based SS uses a JVC hard drive that's a bitch to find these days, as it used a 'special' stripped-down IDE interface. The other possible problem is that the IDE hardware might not be present in the floppy-only model.
Later SS models used standard IDE drives, but were very limited in the drive types they would recognize.
--T
It only has a 10MB HD probably because it has quite the list to choose from so my guess is that it had a LOT of options and the previous owner went the cheap route. *shrugs*
