Hmmm, I don't know if I'd use a table saw--unless you're using a very fine-toothed (or no-toothed diamond) plywood blade, you're running the danger of raising chips on the board. And an FR4 circuit board will not be kind to your blade's teeth either--it's pretty abrasive because of the glass fiber embedded within. If you have to use a table saw because that's all you have, sandwich the board between two pieces of wood and don't raise the blade more than the thickness of the board. I speak from experience. :{ Even my cherished 80 tooth Freud carbide blade raised chips--and it normally gives a glassy finish on wood cuts.
Use a fine-toothed hacksaw if you want, a jeweler's frame saw, or a fine-toothed bandsaw. An abrasive cutoff wheel might also work.
A sharp file held at a slight angle will clean the edge of the board up.
