SomeGuy
A while back I obtained a Davong hard disk controller, and I have been trying to get it to work. This card is unique in that it is was one of the few hard disk systems that supported DOS 1.x. As far as I can tell it should be able to use any MFM hard drive although it would probably only use so much space. The installation program apparently creates multiple small drive partitions since there are no subdirectories, and I assume low-levels the drive.
I have been testing it on a generic turbo-XT clone motherboard, but I can't seem to get any response from it. When I try to run the driver installation tool it just says it can't communicate with the card.
It has some ROMs, but I am not sure if it is supposed to expose a BIOS to the system like normal MFM hard disk controllers. This one is certainly different.
I did discover that oddly, some of the chips are powered from the external connector instead of the ISA bus. I can't tell if there is supposed to be an external power supply attached, or if an external device is supposed to be able to take power from it via the molex connector. But the wiring appears "dumb" so it could go either way. Attaching a molex power connector to the board, and at least chips start to get warm, but still no response.
There is a jumper block on the board, but I can't find any information about that. Does anybody know what they are supposed to do?
Being such an early board, I don't know for sure how compatible it is supposed to be with clones. I don't have a genuine 5150 to test it with.
Any ideas?
I've had to put it aside for now, but I'll check any ideas when I get a chance.
View attachment davong hd drivers 2.4.zip
View attachment davong hd drivers 2.5.zip
Any ideas?
