I found a Model III TRS 80. The CRT mounts were broken. I removed the top/cover and put the CRT into the proper position and it stays in place on its side.
When powed up the drives spin momentarily, but niether drive light comes on. The CRT powers up but does not display anything (if you turn the brightness up you see scan lines).
Is this machine toast, or is there a way to get it to work again? What's a probable cause for a blank screen?
Thanks.
Thanks.
