DEC PRO380/VAX Console real time interface.
leegleason
I have a PRO380 that was formerly a VAX Console system. It has the Real Time Interface installed in slot 5, along with the cable gizmo that goes out the top of the card cage, over and down, and connects to a "block" DB style connector, that is somehow attached to the cabinet of the system. I need that slot for another option. It's not obvious to me how to get that cable gizmo off the machine, and it has to come off to use that slot for something else. Anyone here ever had occasion to install/remove that part?
OK, I figured this out - replying to my question in case anyone else runs into one of these. The real time cable/connector/block gizmo is attached by two screws recessed in deep holes facing into the block. It's obvious now - they're hard to see unless you get down to where they are at eye level.
Do you still have the VAXconsole hard drive? I have an 8550 and haven't been able to find the VAXconsole software for it. Without an image of that drive, the machine cannot be booted and is a very large brick.
Do you have a part number on that internal cable/block? I am trying to locate one. Failing that, is there a way you can provide the pinout from the blue card connector to the external connector. I have the external block pinout, but I don't know how it maps to the card connector to create my own cable.
The part number on it is 17-00404-01A1. Sorry, don't have any info on how the pinout above maps to the connector on the other end. A quick search shows that VARX has one, called "PC38N RTI-NAUT DIST KIT", for $99 - ouch - still, I'd pay that just to avoid building a cable with that many lines in it.
Many thanks for the part number and source reference. I'll check it out. I found some of these inventory lists are stale, and parts listed are not there or impossible to locate. I still may need to make a cable because that internal block connects to an external cable that is also difficult to find. But at least I will have the pinout to the card.
Well, if you get hard up against it and have to make the D connector to blue connector cable, let me know and I'll map the D connector pins to the correspnding rectangular connector pins with a continuity tester. But please don't have me do this until you become really serious about making a cable....there's a lotta pins...also would take some effort making sure we agreed on what pin is where, numbered what on each end.
Much appreciated. I have several searching for the cable. I'll let you know if I meet with any success before resorting to ringing out a 62-pin cable.
Interesting. What are you replacing it with, and why does it have to be in that slot?
Do you have a TMS adapter as well? Or Ethernet?
I had to take it off while I was testing the MicroVAX softcard, which takes up two slots, and I was out of room, so the RTI had to come out temporarily.
Oh yeah, that weird softcard. How is it going?
Other projects are interfering with progress on it. I've put it in a PRO and have probed it looking for registers and memory, with mixed results.
Ok. I mean it's weird and interesting, not sure what the universe would do with it. Are there ROMs that can be dumped/probed?
There's a ROM, but it doesn't contain any code - it was almost all 1's. I'm hoping I can find a way to load software in it and tell it to go. Writing standalone MicroVAX code is pretty trivial, so I'm sure I could get it to do something interesting...if I can just find a way to load it and tell it to start. Well, after I get caught up, anyway. Gotta fix a BA23 power supply and fix a 7551 memory board first, to get enough room on the desk to put the PRO back on the air.
FWIW, I see this on eBay: https://www.ebay.com/itm/305377555471
At least you know that it's real (in stock!). And you can try a more realistic Best Offer.
Yes. With the part number leegleason provided, I found a source (C-U Digital) and more importantly, they were able to locate the part in their inventory. They had a couple. I grabbed one and they put the other on eBay along with some other PRO components that he found along the way. Thank you leegleason. I have yet to find any external cables for the RTI for its application as a data acquisition board.
You mean the PC3XX-AB RTI Cable & Pod I presume? At least the RTI documentation defines all of the connector pin-outs so wiring up a substitute is feasible. Apparently there were specialty cables for subsets of the interfaces (serial = BCC10-03, IEEE-488 = BCC11-03, programmable port = BCC12-03) as alternates to the pod-based all-in-one approach. So you could also search for those PNs.
Yes. I have not been able to find any of those BCC cables or pod. The RTI documentation defines the pin-out for the external connector and not the board-side. Hence the reason to acquire the internal cable.
I received my RTI internal cable and it is a piece of work. At first glance, I wasn't sure how it was going fit into my PRO 380. But those good hardware engineers at DEC had it all worked out. The cable fits to the PRO like a Tetris piece. It has a U-connector to reach over the side of the card cage and connect to the RTI card in the last slot. There are two screw holes on the top of the card cage to screw it in my place. It runs down the left side of PRO as you look at it from the back. I removed a plastic insert in the case and the D62 connector slots in perfectly, adding a D62 shell connector to the back of the PRO just above the DECnet D-shell, like it was built-in. I'm very impressed.
I took a multimeter to the cable to ring out the D62 pins to the card connector. The internal connector has 60 pins in 3 rows of 20, while the external connector has 62 pins in a three-row d-shell. The connector graphic I posted earlier is the female side of the external cable (note pin 1 at the top). The internal cable presents the male side of the D62. Below is the mapping between the card connector and D62 male side for those who do not have the internal cable. At least you can identify the pins on the card and build your own cable. I found a breakout board for the D62 shell connector and will use that in place of the pod.
D62 (Male)Internal Board ConnectorSignal
1A1NDAC
2A2NRFD
3A3DAV
4B4DIO8
5C5DIO7
6B5DIO6
7A7GND SLU
8A8Receive Data B BB
9A9Transmit Data B BA
10C10Carrier Detect B CF
11A11Receive Data A BB
12A12Transmit Data A BA
13GND Parallel 1
14C13PAJ7 H
15C14PAJ6 H
16C15PAJ5 H
17C16PAJ4 H
18C17PAJ3 H
19C18PAJ2 H
20C19PAJ1 H
21C20PAJ0 H
22B1GND 1 (IEEE)
23B2GND 2 (IEEE)
24B3GND 3 (IEEE)
25C4REN
26A5DIO5
27C6DIO4
28B6DIO3
29C7GND Parallel 2
30B8Clear to Send B CB 106
31B9ROST to Send B CA 105
32B10Clear to Send A CB 106
33B11ROST to Send A CA 105
34B12GND Parallel 1
35B13PBJ7 H
36B14PBJ6 H
37B15PBJ5 H
38B16PBJ4 H
39B17PBJ3 H
40B18PBJ2 H
41B19PBJ1 H
42B20PBJ0 H
43C1ATN
44C2SRQ
45C3IFC
46A4EO1
47A6DIO2
48B7DIO1
49GND SLU
50C8Data Set Ready B CC 107
51C9Data TRM Ready B CD 108 2
52A10Carrier Detect A CF 109
53C11Data Set Ready A CC 107
54C12Data TRM Ready A CD 108 2
55A13PCJ7
56A14PCJ6
57A15PCJ5
58A16PCJ4
59A17PCJ3
60A18PCJ2
61A19PCJ1
62A20PCJ0
