Hello, everyone.
I bought a Latitude CPi a couple of days ago. It's a fine machine; when it's working, that is.
After seeing that the BIOS was locked with an administrative password, and finding an archived website detailing on how to remove it on Dells, I did the deed.
It required removing the Pentium II 300 Mhz CPU from the board - MMC-2 socket - to get to the EEPROM chip which held the password. I jumped the 2 required pins and (seemingly) put the CPU back in. It lit up the power LED, caps, num and scroll lock, and stayed that way for a few seconds, powering back off. So I (foolishly) thought the RAM might be the issue, and removed just one stick, but the problem persisted. Next, I turned my attention to the CPU. Well, look at that, it wasn't properly seated! Turns out I didn't clip in the connector at all. So, fingers crossed, i powered it on, and voila! The service menu appeared, and the password was indeed gone!
Next, I proceeded to put that one RAM stick in its slot, and did an obligatory power test.
Whoops.
Now, there's only an orange battery LED lighting up for a second, and powering on the machine does nothing. There's also a rapid, clicking sound coming from the general direction of the NeoMagic GPU-thing, although it was making it while the CPU wasn't inserted as well.
What's weird to me is that the LEDs lit up just the same as in the first paragraph, without the CPU inserted, before i put in that stick of RAM.
I don't see any bent pins on the CPU connector, nor on the RAM. Unfortunately, I don't have spare sticks to test with them, but I'll get some if that's a possible issue. No idea where to get the CPU, though.
So, I dunno what the issue could be. I'm hoping someone here could help me get this sorted out, as this is my first retro machine, and I'd hate seeing it slowly accumulate dust under the bed.
Cheers.
