Did ever exist an 8-bit ISA card for ATA (IDE) hard drives?
Could that limit not be broken by Dynamic Drive Overlay (DDO) software such as EZBIOS, as you would do on later AT+ machines?
Recall that DDO's use their own low-level driver, not the BIOS one.
I doubt that the I/O port mappings directly correspond to a standard ATA setup. There's usually some sort of adaptation employed to handle the 16-bit to 8-bit translation. In particular, note the 2Kx8 SRAM--that's not part of a usual ATA adapter.
Don't forget there were also many "hardcards" which marry the drive and controller onto the card. Does that qualify? Not sure if you can decouple them and wire up a different drive to the card, but there's an 8-bit IDE-ish HDD adapter for you.
The only period-appropriate 8-bit IDE adapter I own is a Silicon Valley ADP50. The rest are XT-IDE variants of various flavors.
Another period-appropriate card was the AccuLogic sIDE-1/16.
The sIDE-1 was an IDE-XT (XTA, 8-bit IDE, whatever you want to call it...) card while the sIDE-1/16 was to use regular IDE-AT / ATA drives with an XT-class machine.
