Marty
Hi All;
Falter, two things, I noticed, first, It looks You have a TVT-64 and not a TVT-32, because of the two columns it shows..
One on the left and one in the middle, that can (if I remember correctly) can be changed, but I don't remember how at the Present..
Secondly, that actually is good that You have gotten that far with it..
I think it might be a 7404 that is bad driving that last row or two of memory, But it could be a Bad Ram chip as well..
The only way to tell, is to pull that last row of Ram, and try only one ram chip at a time in it and see if it messes up the screen..
Once that has been accomplished, and You have tried those same rams in the Video card one at a time, and if they work, Then it has to be either a Bad IC like a 7404 or a Trace short..
I have never had a Cassette Break like that on me, what I suspect is the Tapes were stored in the Sunlight or You Tape player has too much Tension on it on the Take up reel..
Good work Overall though..
"" Anyway, I started re-adding RAMs line by line to the board and powering up to test. The first three rows of 8 on the left side = no problem. As soon as I add the last row on the bottom left side (IC 70-77), that's when it hangs. I did a look around at the soldering and traces but I don't see any shorts, etc. ""
Use a Magnifying Glass !!! And if need be a meter..
""Can the board still be accessed with that one line out? I know you mentioned the boards could work with some rows out, but I wasn't sure if certain rows (like the bottom or top) were special in some way. ""
No they are all the same..
I also think that You still have some Rams that are not quite right, there used to be, but I don't know if You have it, but on the basic Operating System Tape, (Not BASIC) a Memory Testing Program, See if You can find it, that would be alot of Help to You..
Also, check all of the IC's and Rams for black like Corrosion on the pins and if it is there use an Ink Erasure on the pins to clean them some.. There could be the same thing in the Sockets, but the only fix for that is to replace the socket.. And unless You are really good at that I wouldn't attempt it..
I Just had a thought, and so I need to ask, is Row Ic's 70 to 77 Fully Populated ??
If it is not, then Possibly there is part of Your problem, Try this as well, Take out 8 rams from the CPU card, going up and Down, not side to side, the column closest to the 1702 Eprom and put them in that last row (Ic's 70 - 77) of the 8K Memory Board, If You can get them to work in there then You will have 17K of memory instead of 15K of memory and a 1K space and then 2 more K of memory from the CPU..
And that 17K will be as much memory as You can have until You get some 2102 Replacements for Your Bad ones..
THANK YOU Marty
THANK YOU Marty
