lyonadmiral
Is it possible to convert a 500a to a 500au? If so, how?
Thanks,
Daniel
Thanks,
Daniel
I don't think SRM is loaded right now; displays the PWS screen then goes to AlphaBIOS first off, no settings in there that would allow me to go to SRM. I'm looking for firmware, haven't found it yet... might you have any insights?You make sure your I/O cards are compatible with the non-Windows OS you want to run, and then set the machine to boot the SRM console instead of the ARC console. That's it.
The 500a/au is one of the machines that can have both the ARC and SRM console software flashed simultaneously. I don't know if the 500a shipped with the SRM console code flashed in. If not, trying to switch the first time will prompt you to insert flash update floppies. IIRC. You only have to do that once; after it has both consoles loaded you can switch between them at will. There's no lockout PAL like there is on e.g. the NT-only AS4x00 processor boards.
Switching from Windows NT to DIGITAL UNIX
To switch from the Windows NT operating system to DIGITAL UNIX, follow these steps:
1. From Windows NT, choose Shut down.
2. Restart the computer.
3. Press [F2] to enter AlphaBIOS Setup.
4. To change console selection, from the Setup menu, choose CMOS Setup.
5. Press [Enter].
6. Press [F6] to enter Advanced Setup.
7. Tab to Console Selection.
8. Select Digital UNIX (SRM).
9. Press [F10] twice to save your selections.
10. Press [Enter].
11. Press [Esc] to exit Setup.
12. Power cycle the machine.
NOTE: Wait 45 seconds before turning the system back on.
13. The SRM console prompt >>> displays
Thanks, I should have taken the time to RTFM, that worked. I appreciate your guidance and patience.Have you tried this:
Pages 3-28/29 in the first manual I linked to in my post.
Sometimes you just can't tell what manual will help. Fortunately/unfortunately, there isn't much left out there for the PWS so it wasnt too hard.Thanks, I should have taken the time to RTFM, that worked. I appreciate your guidance and patience.
