atod
Folks,
I'm trying to create an "ImageDisk" system to image my 8" floppy CP/M disks. This system will be using an Adaptec SCSI card with floppy controller built into the card. I need to *disable* the motherboard floppy controller to get this working.
I read the manual for the Dell below (found on Ebay) and it didn't have a jumper to do this. It indicates in BIOS there is an "Integrated Devices" section, where "Diskette Interface" is listed as follows:
* Diskette Interface controls the operation of the system's built-in diskette drive controller. With Auto (the default option) selected, the system turns off the built-in diskette drive controller when necessary to accommodate a controller card installed in an expansion slot. With Write Protect selected, nothing can be written to diskette drives and tape drives using the system's built-in diskette drive controller. (The system can still read from the drives.) When this option is selected, the Auto option (whereby the system turns off the built-in diskette drive controller as necessary) is also in effect. Selecting Off turns off the built-in diskette/tape drive controller; this option is used primarily for troubleshooting purposes.
Does anyone recall if "Turning Off" the built-in diskette drive controller will let me using the one in my Adaptec SCSI card?
Pic of the computer to refresh memory:
Uploaded with ImageShack.us
Thanks so much!
Thanks so much!
