I've run up against a problem using a HxC Gotek with my TL/2's internal FDC. Reading works fine, but not writing - it's like the Gotek just doesn't receive the write signals. Have confirmed it working with a real floppy drive, so it's definitely the Gotek at fault. Tried a second Gotek too.
Using an ISA FDC should cure this, but I need some way to disable the built-in FDC. The TL/2 has a FDC disable option in SETUPTL /A, but the readme for the NOFLOPPY utility says it doesn't work. NOFLOPPY is a small program that toggles some bit to disable the internal FDC and allow an ISA FDC to take its place.
The downside of NOFLOPPY is that you obviously need to boot first, so no booting from the ISA FDC.
Perhaps it's possible to toggle the same bit that NOFLOPPY does from within expansion ROM code (e.g. XT-IDE booter) to allow booting from an ISA FDC?
Thoughts welcome and I'll post here with my findings. Thanks
