Never mind; if Carlsson or someone sends you a replacement 8032 CG ROM you'll probably be in business.My collegue did look through all these chips and draw a blank. H'es got a good 15 years more experiance then me.
I can't rummage through them now as everything is at work.
But we're curious: what *are* those pretty purple ones with the round labels?
Hey, your intuition was right on! There's a future in troubleshooting PETs waiting for you...Very Very Clever Mike
Well, if you have the facilities to erase and (re)program EPROMs and somewhere in those drawers you find a 2716, 2532 or a TI 2516 (check the chips with 24 pins and a window) then you download the appropriate image (901447-10) from one of several sites and program a new EPROM with it. Failing that, you ask one of the generous and helpful folks on here like Anders and Steve to send you one (I would and Dave probably would as well, but it'd take a while; I assume someone closer can help).So Fab Forum'ers as a novice (but one who works at a Uni and obviously have stuff around which may or may not help) where do we go from here?
We all love to drool over pictures of neat old stuff, but if there are more than two or three it might be better to put them on one of the numerous free photo sites and just post a link here. Looking forward to seeing what you've got there!I'll relook at work and get any numbers off them. Theres a yellow, orange and blue circular ones
Shall I take my camera into work next week and take a pic of some of the old bits we have on display or is that just "done to death on here"?
We've got everything from Galaxy 2000's to punch card readers lol
I second the motion. The ROM is more likely to be the cause of the problem, but it could indeed be the 74166 at UA2; removing the CG ROM doesn't really prove anything since it just lets all the data lines float high including the two that are probably stuck high already, but another ROM would most likely pull those lines low somewhere in the CG table so if the bars disappear that would indicate that the SR is OK and it must be the ROM.I still think it'd be worth taking two minutes to try another ROM in the CG socket - as far as I can tell, any of the other ROMs on the board would do. The reason is that a broken shift register could cause exactly the same symptoms. If Mike wants to get his soldering iron out and lift a couple of inputs on the 74166 I'm sure he could reproduce the above screen shot yet again ;-) My money is also on the ROM being toast, but it would be a shame to fit a new one just to find out that it's the shift register that needs replacing (and that the original ROM was probably perfectly good from the start!).
Try the irrelevant UD11 or even UD10. I assume that since it failed while just running, a broken or bent pin is not the problem; be careful not to bend/break any pins now though!
No to worry about the PROMS in UD11 (address hex A000) or UD12 (address hex 9000), they are for user installed machine language programs and are not part of the operating system. The code there can not be executed without being called with a SYS command. Mike was just suggesting that the chip at UD11 would be a good candidate to drop into the character generator spot as it is pin compatible and is not needed by the operating system. The actual code in the chip was irrelevant for this test. But if you think the chip may have a problem, do not use it. It is OK to leave it off the system board.
The soldered pin may have been attached to the chip as a test point to clip-on a scope lead.
I agree, at this point in the testing, it is best to make arrangements with Anders. For a few quid, it is a very good deal. The 2532 EPROM is worth more than that without the programming.
That's why I said to look for 2716s and TI 2516s as well as 2532s; this discussion seemed to assume that the CG ROM is a 4K 2332/2532 type instead of the much more common 2K 2716 type (probably because of the suggestions to replace it with a 4K ROM from elsewhere for testing).Actually I went through my boards this morning and noticed they all have 2716 EPROMs. <snip>
Since I already have piles of 2516 and 2716 chips,<snip>
