facattack
Everything is plugged in. I swapped the default power supply in and took out the black one that came with Vulcan hard drive. Then I removed the default power supply and put back in the black one. The plug that goes into the motherboard seems to only fit in one way.
The machine does show a scrambled screen on the RGB monitor. I do notice that the power light on the Apple IIGS doesn't completely light up. It's attached to a power strip. Can it not be recieving enough current?
I know from experience that daisy-chaining the disk drives together and into the machine is tricky. Could things have broken when I drove it to the new location? But the disk drives aren't being accessed.
