One day at the computer store, the subject of file compression came up. Between Mark & myself, we had a couple of customers believing that if you ran your software through a series of compression programs, (sQueez, then CRunch, then LHA, then Pak, then ARC, then Zip, etc) that eventually you could compress all of your data down to a single byte. The clincher was when I suggested that you could then send that byte thru a modem that does file compression (MNP-5 was the big thing back then), and you could eliminate the need for mass storage at all, because not only would the byte be compressed again to a single bit, that bit would remain floating around in cyberspace until you were ready to download it back into your system.
--T
