CP/M User
2 Things I discovered from the Journals:
I came across a "Line Drawing Game for your Video Terminal" Oct 1976 page 30, or page 290 on Archive, written for an 8080 based machine, but I don't have much information about what that machine is, it uses a VDM (Video Display Monitor I presume), which has a PORT accessed at 8Ch and memory assigned to it between 8800h and 8BFFh. Within the Game source code itself is a Couple of IN statements using PORT address FFh and the source was written in 8080.
The funny thing about this game was I was able to rewrite the code into Z80 to understand a little bit clearer for myself, a lot of the initialization code was removed, which looked like this:
I figured that to draw some things to screen to simply use what my machine had and hopefully all the other pieces would fall into place, which on this occasion seems to be the case when I used what my machine had in terms of Input & Output to make this work, I had to come up with some other things, which i was able to do to determine when the game is over, though the original game appears as if it's able to read based on where the object is on screen, with this bit of code:
Which simply jumps to the HLT routine, which appears to pause for an Input (using IN 0FFH again), then restart.
I was simply wondering what sort of machine this was written on, I can only imagine that because the code was so short and well commented, I was able to substitute what would work on my computer.
The 2nd thing I became intrigued with regards Tiny BASIC and how a number of versions were created on computers with 4k. I had a look specifically at Palo Alto Tiny BASIC, though initially didn't realise they were created for TTX based system with 8080 processors, though I had to wonder if I could persevere on it if it could be created to function under VDM, or perhaps when I was reading about this Language being translated if perhaps CP/M had a version? I'm a bit confused if it had since Tiny BASIC was designed for systems with small amount of memory, but I thought if I was going to try and understand Languages better, then finding something small would be a good start.
LXI 6,SP+6 Set Stack Point
MV I A,0
OUT 8CH
AG LXI H,8800H Initialize screen
ST MV I M,20H
INX H
MOV A,h
CPI 8CH
JNZ ST
N2 MOV A,M
CPI 2AH
JZ HLT
