squirrel-steam
I have a quantex with a Am486dx4-S 120mhz and im thinking of gutting it and using the case for a retro styling case for my gaming computer, it has a little mhz display on the front. I think it runs on 5v power, but i took my volt meter and hooked it up to the leads for it (it runs on a special connector directly from the power supply,) and it showed up as 3.3v. Confused, I connected the voltmeter to the 5v wires on the molex adapters from the power supply, and it showed up as the same 3.3v. Then i tested the 12V leads, and it showed up as 10v. I think the power supplies they used in them (AGI,) were pretty spotty. This computer had it replaced in '97. So I guess after 11 years, you might see some drop in voltage. But I can't believe the comptuer runs so good on that large of a drop of voltage.
Also, do you guys think its ok to gut that computer (it actually was a pent 1 75mhz, but i downgraded it to a am486dx4-s cpu,) or should i keep it. It would make a really cool new case mod.
