Hello,
Yes, thanks for this. The document was already available (from long ago ?) but this version is a much better image, and displays the actual photos which is a great improvement.
Should be a big help to keeping my HX operating. I know it's a fight against time anyway, but it was my first computer so I must try.
Latest problem is with some of the keys stopping working. Always the same 7. Seems to be something to do with temperature, or humidity? They tend to work fine all summer, have problems most of the winter. I've just now reprogrammed the PF keys to replace the missing keys, these still work fine, as a temp fix.
Could do with getting the m/c working again, even if temp so I can read a couple of tapes and re-save as .WAV - using .WAV via CAS1: seems to work fine, with progs, just now doing some experimants to see how the process behaves with data. Anticipating some timing problems, but so far seems to work OK.
Geoff
