Hi all
I've recently got into the early Epson portable computers, and got hold of an HX-20 (which works perfectly) and most recently a PX-8 / Geneva. This is proving a bit more of a challenge though and I was wondering if anyone had any pointers.
I'm aware of the various issues with batteries - I've replaced the main battery with a new pack. The internal battery is dead but doesn't appear to have leaked although I will get it out soon before it causes any issues.
The issue is that on trying to power it up, nothing much happens. I've plugged in the AC adapter with the battery in place. The screen does show some signs of life, with the occasional line on it, and if I turn the contrast up to the max you can see a faint pattern on the screen but that's about it. It doesn't seem to make any difference whether the main power switch is on or off, and pressing the various reset buttons doesn't seem to do anything. There are no beeps, and none of the keys do anything nor do any of the lights come on.
Having a close look at the board, quite a few of the capacitors in the power supply section have got signs of corrosion on the solder joints, as have a few of the other components - although most of them look absolutely fine and overall the board looks clean.
So I'm thinking it probably needs recapping as a starting point... but wonder if anyone else has experienced this or has any advice?
Thanks
James
Thanks
James
