hackerb9
I'm ok with the BIOS, as putting it in any clone would have the same argument and there's nothing wrong with that.
Well, I will happily admit that you would know better than I do.
I'm wondering if Andromeda ever disabled Plug and Play on the card using 3CCFG. If not, that would explain the error when trying to find an available IOBASE address, right?
Perhaps the very first error mentioned:
3CCFG CONFIGURE /PNP:DISABLED said:!!! ERROR !!! the configuration parameter specified is only available for 3C509B NICs in ISA Mode
is the key.
Maybe the card is in EISA mode.
Hey @Andromeda92, please try the following:
3CCFG CONFIGURE /IOBASE:ISA
3CCFG CONFIGURE /PNP:N
If that doesn't work, could you try disabling EISA in the 3CCFG program? From the Test menu, go to Install, then Modify. Pick I/O Base Address and use the arrow keys to pick "ISA".
Thanks.
