Mike Chambers
- Joined
- Sep 2, 2006
- Messages
- 2,655
started from scratch on this one 4 days ago... let me know what you think if you try it! make sure ya edit your IRCDLITE.INI file and MOTD.TXT if you run it.
http://www.rubbermallet.org/ircdlite83008.zip
works on an 8088 with 2 seconds lag or so... 286 = almost no lag. and there is a simple built-in web server that spits out basic status info on the connection handles. you can change the port for that in the INI. i'm sure there are bugs let me know if you run into one, but it works without crashing it seems. DOSIRCd code was all convoluted i thought a fresh start would be good. i'm keeping it more simple as well. no services, at least for now... we'll see what happens.
and of course it's up and running live on an 8088 at irc.rubbermallet.org port 6667
we're all in #wtfpwnt
WHOOPS! important edit: if you download and run it, i forgot to mention that NTCPDRV has to be started like this to allow more than the default 8 connections or your IRCd event log will fill with endless errors:
NTCPDRV.EXE <ip_address> 20
