BTW: Here is a MS document outlining major and minor changes between DOS 6.0, 6.2, 6.21 and 6.22
The MS-DOS 6.22 Step-Up improves on the safety and ease-of-use provided by
MS-DOS 6.x, and is designed for users of Microsoft MS-DOS 6.0, 6.2 or 6.21 only.
This file explains what functionality changes your system undergoes when you
use the MS-DOS 6.22 Step-Up; these changes depend on your current version of
MS-DOS. This file also describes features in MS-DOS 6.22 that are new
since MS-DOS 6.0.
If you currently have:
MS-DOS 5.0 or before
If you have MS-DOS 5.0 or earlier, you cannot use the Step-Up to
install MS-DOS 6.22. To upgrade your version of MS-DOS, obtain the
full MS-DOS 6.22 Upgrade instead.
MS-DOS 6.0
You'll gain all of the MS-DOS 6.22 features and functionality,
including Data Protection Technology. You can either keep
DoubleSpace compression or replace it with DriveSpace compression.
MS-DOS 6.2
You will not gain any incremental functionality other than the
opportunity to convert your DoubleSpace drives to DriveSpace.
MS-DOS 6.21
You'll gain the DriveSpace compression technology and all of the
other features listed in the following section.
Safety Features and Enhancements
* MS-DOS 6.22 includes ScanDisk, a utility that detects, diagnoses, and repairs
disk errors on uncompressed drives as well as both DriveSpace and DoubleSpace
compressed drives. ScanDisk can repair file system errors (such as crosslinks
and lost clusters) and physical disk errors. ScanDisk keeps a log of its
repairs and enables you to undo any of the changes it made. DriveSpace
runs ScanDisk to check the reliability of your disk before it begins
compression. You can also run ScanDisk yourself by typing SCANDISK at the
command prompt.
* DriveSpace includes DoubleGuard safety checking, which protects your
data by verifying data integrity before writing to the disk. If DoubleGuard
detects that the memory DriveSpace is using has been written to by another
program, it notifies you and recommends you shut down your computer
immediately to minimize damage to your data.
* The MS-DOS extended-memory manager, HIMEM, automatically tests your
system's memory when you start your computer. This test can identify
memory chips that are no longer reliable. (To turn off the memory test,
add the /TESTMEM:OFF switch to the command that starts HIMEM.)
* Setup now configures SMARTDrive as a read-only cache by default. Even if
write-caching is enabled, MS-DOS does not display the command prompt
until SMARTDrive has written its cache to your disk.
* The MOVE, COPY, and XCOPY commands now ask you for confirmation before
copying a file over another file that has the same name. (However,
to maintain compatibility with existing MS-DOS batch files, these
commands do not prompt for confirmation before overwriting a file
when issued from a batch file.)
Ease-of-Use Features and Other Enhancements
* SMARTDrive now caches CD-ROM drives.
* DriveSpace automatically mounts compressed floppy disks and other
compressed removable media -- even when Windows is running.
* You can easily uncompress a DriveSpace drive or even completely
uninstall DriveSpace from memory.
* You can easily convert a DoubleSpace drive to DriveSpace format.
* Interactive Start (the F8 key) has been enhanced so that you can now bypass
or carry out individual commands in your AUTOEXEC.BAT file and other batch
programs. (In MS-DOS 6, this capability was limited to your CONFIG.SYS
file.) This feature makes it easier to troubleshoot your system configuration.
* The DISKCOPY command now uses your hard disk as an interim storage area,
which makes copying from one floppy disk to another faster and easier.
* Microsoft Defragmenter makes better use of your computer's extended
memory, so it can now defragment much larger disks and disks containing
many more files and directories.
* The output of the DIR, MEM, CHKDSK, and FORMAT commands is much easier to
read, since it now includes thousands separators when displaying numbers
greater than 999. For example, "1000000 bytes free" now reads "1,000,000
bytes free."
