MarsMan2020
Does anyone have a PDF of the patterns that would be stuck onto a floppy spindle used with a strobe to measure the speed?
The patterns differ between drives that spin at 300 and those that spin at 360 RPM. Which do you have--and what size?
Better to use program that simply times the space between index pulses, I think.
What model are they? Someone else might have some information.They are 1.2 MB 5.25 drives, with no readily available manual online. I am trying to determine if there is a way to get them to run at 300 RPM.
I guess it might not be too bad to jumper in a motor on signal and measure the index pulse timing with a logic analyzer.
Exactly what are you trying to do here? Some 1.2mb drives do in fact have jumpers or options that let them run at 300RPM. However, this mode is not very useful. In this mode a 1.2mb drive can be used as a quad density (720k) drive on a low density controller. It can NOT operate as a proper compatible 360k drive because it is still a 96TPI (80 track) drive rather than 48tpi (40 track).
