Floppy write protect question
dittman
Plano, TX
8" floppies require the notch to be covered to enable writing to the disk.
5.25" floppies require the notch to be uncovered to enable writing to the disk (and 3.5" drives require the hole to be uncovered to enable writing to the disk).
I've always wondered why this was reversed when the 5.25" format was created but never heard an explanation.
Does anyone know why?
No, 3½" disks are write protected when the hole is uncovered. They require the hole to be covered to write to the disk.
Practicality. You can manufacture write-protected 5.25" floppies that cannot be write-enabled easily, yet it's easy to manufacture write enabled floppies just as easily. When software began to be distributed on floppy, this became important. The same idea obtains for 3.5" floppies--produce them leaving out the write-enable slider and you have a write-protected floppy without having to change your production equipment.
That makes sense.
