Format taking forever (don't know if it's normal?)
Thx1138
South East England
Hi,
I have an old Epson Equity 286 portable with what I'm guessing is a 2Omeg or thereabouts hard disk.
I'm trying to format it and install DOS.
When I run format on it first displayed:-
Head: 0 Cylinder: 168
It has progressed very slowly (an hour) with the head going from 0-3 and then the cylinder increasing by 1 to Head: 0 Cylinder: 172
Is this normal, it seems to be doing something but taking forever.
Charlie
Chuck(G)
25k Member
Pacific Northwest, USA
No, it's not normal--and I wonder if the format routine is flagging scads of bad sectors. The usual process for error recovery involves a (slow) recalibrate and retry several times. It can take forever if you've got lots of bad sectors.
On many drives, you can actually hear the retry going on--the heads are stepped slowly (3 msec per track) cylinder 0.
Thx1138
South East England
Thanks Chuck, my assumption was that it was probably caused by some sort of disk damage. I decided to give up and run fdisk again, creating a 4 meg dos partition instead, avoiding the rest of the disk. I've been able to install DOS onto the hard drive now.
The drive is a JVC JD-3824R RLL 20MB.
Charlie
Chuck(G)
25k Member
For whatever reason, it seems that some drives degrade with age. Perhaps it's a fault of the binder used in the platter coating. I've got a small pile of early Conner 3.5" drives that exhibit this behavior. It wouldn't surprise me if your drive wasn't suffering the same sort of aging.
Generally, plated-media drives seem to survive better than coated-media ones. So high-end drives survive better than the economy ones, in my experience.
Chuck(G)
25k Member
Since that's a RLL drive, I wonder if a Low Level Format would help the situation.
I'd (perhaps foolishly) assumed that a low level format had been done already. When I was still making extensive use of MFM and RLL drives and was getting ready to reload the contents, that would be the first thing that I'd do.
Sometimes I assume that everybody knows that you do something, but that's me forgetting that this stuff was 25+ years ago. Sort of like assuming that everyone knows how to do phasor math on a slide rule...
Ole Juul
Coalmont, BC, Canada
. . . Sometimes I assume that everybody knows that you do something, but that's me forgetting that this stuff was 25+ years ago. Sort of like assuming that everyone knows how to do phasor math on a slide rule...
As I understood it back then, you were supposed to do a LLF as a matter of maintenance. I used to do that because that's what I was told. Like you, I assume that people know that. How did that little piece of information get so lost in just a few years?
Chuck(G)
25k Member
I don't know, Ole. One of the big selling points initially of SpinRite was that it could do a LLF on your MFM/RLL drive without destroying your data. The idea being as mechanical wear causes some "drift" (this is before 5.25" drives with closed-loop servos), you could adjust the disk format to compensate.
modem7
Melbourne, Australia
I had been reading about low level formatting and might try that in the future, do I need specific software to do that?
Epson's documentation for the machine is on their web site. In the 'Product Support Bulletin(s)' PDF is a 'Commmon Questions and Answers' bulletin. In that, Q20 addresses a low-level format. Epson's answer is basically that users don't need to do a low-level format and for that reason, the HDFMTALL program is not on the LT Reference Diskette.
Interesting because elsewhere, Epson clearly promote use of their HDFMTALL program (and HDPART/HDFORMAT).
HDFMTALL.COM is at http://114.130.27.10:8086/S_O_F_T_W...-_SOFT_-_COLLECTION/System Utilities/Lowlevel
HDFMTALL.COM won't be the only method.
