mloewen
Has anyone done any work on interfacing FreHD to a Tandy 6000? My two original 15MB drives are still working, but who knows how long that will last?
Some work has been done by Fred and Ian; there were still issues as I recall. One root issue, as I recall, was that FreHD uses some of the Z80CTC ports for other functions, but the Z80CTC on the hard disk interface card is required for Xenix HD operation (the CTC generates the Mode 2 interrupt vector necessary). Fred or Ian can talk with greater knowledge than I, but that's one thing I recall. LS-DOS 6.3.1 does not require the CTC, as the LS-DOS 6 HD driver doesn't use interrupts.
I'm not sure that the xtrs code on which FreHD was based emulates the IRQ capability of the WD1010 chipset, and even if it does I don't know how well-tested it is.
The main issue is that I don't have access to a model 2/12/16... so I can't test. I tried to enhance the pic firmware to handle the interrupt, but again without a machine, it's almost impossible to debug. I am since looking for a model 2/12/16, but so far, none has become available near me (Luxembourg or Belgium)...
-Fred
The acid test would be Xenix 3.2, but you need the upgraded 68K boards (6MHz with a PAL swap or the 8MHz).
We could probably write a driver for LS-DOS 6.3.1 that required the IRQ, but trying to debug a driver and FreHD at the same time would be difficult. The Model II/12 TRSDOS II 4.2 can be hard disk ready; I've never run TRSDOS II from a hard disk, though, so I have no idea how that works. Xenix isn't very difficult from the user interface to set up, but there is no source in the wild and z80ctl (which does all the I/O) is famously obfuscated. It might be possible to reverse-engineer z80ctl and drop a non-IRQ HD driver into it, but it might be easier to get IRQ's working in FreHD.
And this all assumes the Tandy interface board; the Hans-01 board has no CTC and thus won't work. It would be nice if FreHD could do the Z80CTC emulation, but there may not be enough code space in the PIC to hold it.
