Had a brief look at the Blinkenbone and QProbe projects.
As I understand it the Blinkenbone is like the PiDP-11 a physical replica of a front panel connected to a PDP-11 emulator.
The Qprobe has some interest for LED status o/p - I presume that there is an RSX11M driver mod available to run the display in the idle task.
Is there a means to detach the LED display and make it remote from the Qbus card? My card cage is at the back of the Micro-PDP and so the LEDS would only be visible with the cover off when doing diagnostics. I would like the Frontpanel on top of my Micro-PDP.
Peter
Peter,
I can provide some info on the QProbe and the RSX11M idle pattern. The QProbe does display
the RSX11M idle pattern on a 11/73 but not on an 11/83 or 11/93 because they access memory
either on the PMI bus or on the CPU board.
One interesting quirk on this QProbe behavior and the 11/73 is that the CPU cache must be
active. If cache is disabled, then the pattern is not visible, so I believe that the 11/53 that is a J11
with cache disabled would not display it. Also, I don't think an 11/23 would display it. A key
function of the QProbes CPLDs is to demultiplex the data and address lines and latch them
separately. I think the cache function allows the data to be displayed long enough to create
a visible pattern.
Joerg designed the QProbe as a hydrid between his earlier UniProbe and some ideas from
the Display-11 from QB Technology. The Display-11 card came from Al Kossow who had one
on EBay a while back. The Display-11 used TTL components and did not have a logic analyzer
interface like the UniProbe or QProbe. The serial number on that Display-11 was 100009A
so I think there were not many ever made (maybe 9?).
Joerg and I have talked about the possibility of a modified QProbe where a pair of 34 pin
ribbon cables would connect to headers on a modified QProbe (logic analyzer connections
not needed) then route to a front panel that fits in a 5 1/4" floppy disk bay on the front
of a BA23 or BA123. The front panel would have the mating 34 pin headers to bring
the 60 LED signals and some common ground or +5V power.
The Qprobe uses very small LEDs that have to be carefully fitted into a 3D printed
holder. This allows all signals to be displayed in a dual width Q bus Card. It is a great
diagnostic tool but can't be seen with the case closed.
A slightly larger front panel perhaps a full height 5 1/4" bay could hold the 60 LEDs
and still have room for labels and maybe big LEDs for disk drive activity lights from the
QBone.
Also, I would rather see LED Segment Bars commonly used in VU meter applications
that would fit in 20 pin DIP sockets to make assembly easy. The face plate could still
be made from a piece of circuit board that takes advantage of the small labeling and square
hole cutting available from PCB fabricators. Some spacing of functional sections of
the display could be accomplished by leaving some LED segments dark.
I like you would love to have LED panel displays for my QBus systems. I have reannimated
a couple real PDP-11/70 consoles (one blue & white and later a purple & pink one)
with Joerg's Blinkenbone boards. If you are lucky enough to have real PDP-11 consoles
with blinken lights this is much easier than it once was when you had to either wire wrap
or create custom ribbon cables to interface with teh 3 40 pin connectors.
Oscar's great PiDP-11/70 put PDP-8 and PDP-11 Blinken lights in reach for everyone
but it would still be great to have something like it for real Qbus systems.
Best,
Mark Matlock
