FS: RS-232 A/B switches (new)
komputer
Vernon, CT
I have two A/B switches, both are new and nicely made (thick sheet metal, high quality switches). One has male RS-232 connectors and one has female RS-232 connectors. $10 each or $15 for both.
-- Rich
konecc [at) snet . net
9 pin or 25 pin D-sub connectors, Rich? Do the switches switch all lines or just selected signal lines?
Good questions -- I forgot to mention that they're 25-pin D-sub connectors. As far as the line switching, I'll have to check with an ohmeter tomorrow or open up the cases to take a look, will let you know.
I opened the cases, all 25 pins are switched. Very nice looking soldering, not your usual Chinese junk. According the the box the connector pins are gold-plated. Please give me your zip code and I will give you a shipping price.
Thanks Rich, but I've already got a couple of those--including a 4-port (ABCD) switch. Just trying to get some clarity on the devices for others.
The nice thing about these is that they can be used to switch any device whose connection can be expressed in 25 conductors. I've even used one to switch a SCSI drive between systems.
