vwestlife
I had this listed on eBay but the winning bidder turned out to be a scammer so I am posting it here instead.
The Zenith eaZy PC is a rare all-in-one XT-class PC from 1989, with a NEC V40 (V20 / 8088 compatible) CPU running at 7.16 MHz, 640K of RAM (512K on the motherboard plus another 128K in an expansion box attached to the back), a built-in 14" paper white monochrome CRT monitor with hi-res 640x400 text mode and dual-scan CGA-compatible graphics (640x200, 320x200, and 160x100 with up to 16 shades of gray), a 3.5" 20 MB Western Digital IDE-XT hard drive, a 3.5" 720K floppy drive, and included matching Zenith eaZy PC keyboard with Alps mechanical key switches. On the back it has a parallel printer port and a serial mouse port (I tested it with a Microsoft serial mouse and it works fine -- the driver for it is included).
The case has some yellowing and scars from where previous shipping damage was repaired, but the computer works perfectly. I replaced both the hard drive and floppy drive as the originals had failed with age. The hard drive now has a clean installation of Zenith MS-DOS, Windows 3.00A, Microsoft Works 3.0 for DOS, Norton Utilities 6.01, and various games and utilities on it. The CRT monitor is sharp and bright and the keyboard is a delight to type on.
Asking $85 or best offer.
It will be packaged very securely to hopefully prevent any further shipping damage and insured, or you can pick it up in central New Jersey.
