Chuck(G)
25k Member
After a couple of decades, machines and assemblers look pretty much the same. The 8088 looked pretty much like a juiced-up 8085. Consider this: the DAA instruction dates from the Intel 4004.
1. I keep a small MASM-compatible assembler on my IBM PC for on-the-fly debugging, and it doesn't appear to support the memory models (Arrowsoft Assembler).
Why not just use actual MASM on your IBM PC? (I'm guessing you are using MASM 6.x directives/constructs and 6.x doesn't run on the IBM PC)
There isn't two versions of 6.10 and 6.11. There is only one version based on Win32 + the DOS extender. You see, it uses the DOSXNT extender which implements a subset of the Win32 API.6.11 does work with DOS--there are actually 2 versions of 6.11--a Win32 version and a DOS version that uses the Phar Lap extender. Sadly, that leaves out the 8088. I haven't checked 5.x.
000000 4D 5A 90 00 03 00 00 00-04 00 00 00 FF FF 00 00 MZ..............
000010 B8 00 00 00 00 00 00 00-40 00 00 00 00 00 00 00 ........@.......
000020 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
000030 00 00 00 00 00 00 00 00-00 00 00 00 D0 00 00 00 ................
000040 0E 1F BA 0E 00 B4 09 CD-21 B8 01 4C CD 21 54 68 ........!..L.!Th
000050 69 73 20 70 72 6F 67 72-61 6D 20 63 61 6E 6E 6F is program canno
000060 74 20 62 65 20 72 75 6E-20 69 6E 20 44 4F 53 20 t be run in DOS
000070 6D 6F 64 65 2E 0D 0D 0A-24 00 00 00 00 00 00 00 mode....$.......
000080 F8 9E AC 02 BC FF C2 51-BC FF C2 51 BC FF C2 51 .......Q...Q...Q
000090 BC FF C3 51 FC FF C2 51-DE E0 D1 51 BF FF C2 51 ...Q...Q...Q...Q)
0000A0 54 E0 C9 51 BD FF C2 51-3F E3 CC 51 A8 FF C2 51 T..Q...Q?..Q...Q
000000 4D 5A 80 00 33 00 0E 00-08 00 41 02 FF FF 61 06 MZ..3.....A...a.
000010 00 20 00 00 18 21 20 00-40 00 00 00 00 00 00 00 . ...! .@.......
000030 00 00 00 00 00 00 00 00-00 00 00 00 80 66 00 00 .............f..
000040 3C 00 00 00 40 00 00 00-44 00 00 00 48 00 00 00 <...@...D...H...
000050 4C 00 00 00 04 00 ED 04-ED 0D 20 00 6A 0D ED 04 L......... .j...
000060 6E 0D ED 04 18 00 05 06-26 21 20 00 FF 21 20 00 n.......&! ..! .
000070 00 00 E8 04 E3 0D ED 04-00 00 00 00 00 00 00 00 ................
000080 43 6F 70 79 72 69 67 68-74 20 28 43 29 20 31 39 Copyright (C) 19
000090 38 36 2D 31 39 39 31 20-50 68 61 72 20 4C 61 70 86-1991 Phar Lap
0000A0 20 53 6F 66 74 77 61 72-65 2C 20 49 6E 63 2E 00 Software, Inc..
0000B0 00 00 43 35 53 32 53 32-50 4D 00 00 00 00 DC 4F ..C5S2S2PM.....O
Ah, I suspect only the DOS stub is different and both are still PE executables. FYI, I checked the Win98 DDK version and it has the Phar Lap DOS extender stub.Sigh. Nobody believes me any more.
Okay, the first MASM 6.11 (ML.EXE) that's included in DDKs and usually comes with just ML.ERR and runs only on Win32 systems:
Code:000000 4D 5A 90 00 03 00 00 00-04 00 00 00 FF FF 00 00 MZ.............. 000010 B8 00 00 00 00 00 00 00-40 00 00 00 00 00 00 00 ........@....... 000020 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................ 000030 00 00 00 00 00 00 00 00-00 00 00 00 D0 00 00 00 ................ 000040 0E 1F BA 0E 00 B4 09 CD-21 B8 01 4C CD 21 54 68 ........!..L.!Th 000050 69 73 20 70 72 6F 67 72-61 6D 20 63 61 6E 6E 6F is program canno 000060 74 20 62 65 20 72 75 6E-20 69 6E 20 44 4F 53 20 t be run in DOS 000070 6D 6F 64 65 2E 0D 0D 0A-24 00 00 00 00 00 00 00 mode....$....... 000080 F8 9E AC 02 BC FF C2 51-BC FF C2 51 BC FF C2 51 .......Q...Q...Q 000090 BC FF C3 51 FC FF C2 51-DE E0 D1 51 BF FF C2 51 ...Q...Q...Q...Q) 0000A0 54 E0 C9 51 BD FF C2 51-3F E3 CC 51 A8 FF C2 51 T..Q...Q?..Q...Q
Next, the MASM 6.11 (ML.EXE) that was offered as a standalone product. Runs fine under plain DOS under a 386+ system; windows not needed:
Code:000000 4D 5A 80 00 33 00 0E 00-08 00 41 02 FF FF 61 06 MZ..3.....A...a. 000010 00 20 00 00 18 21 20 00-40 00 00 00 00 00 00 00 . ...! .@....... 000020 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................ 000030 00 00 00 00 00 00 00 00-00 00 00 00 80 66 00 00 .............f.. 000040 3C 00 00 00 40 00 00 00-44 00 00 00 48 00 00 00 <...@...D...H... 000050 4C 00 00 00 04 00 ED 04-ED 0D 20 00 6A 0D ED 04 L......... .j... 000060 6E 0D ED 04 18 00 05 06-26 21 20 00 FF 21 20 00 n.......&! ..! . 000070 00 00 E8 04 E3 0D ED 04-00 00 00 00 00 00 00 00 ................ 000080 43 6F 70 79 72 69 67 68-74 20 28 43 29 20 31 39 Copyright (C) 19 000090 38 36 2D 31 39 39 31 20-50 68 61 72 20 4C 61 70 86-1991 Phar Lap 0000A0 20 53 6F 66 74 77 61 72-65 2C 20 49 6E 63 2E 00 Software, Inc.. 0000B0 00 00 43 35 53 32 53 32-50 4D 00 00 00 00 DC 4F ..C5S2S2PM.....O
Looks like two different versions to me. The core code may be the same, but they're not the same.
You don't need to. Win32 will detect the PE header and run it natively regardless of the DOS stub used. And I think the XP DDK shipped with MASM 7.0, or did it ship with both?Yup, I think the XP DDK has the the native Win32 executable. I think the core code is the same or very close for both. There are some differences in the ML.ERR files, but I suspect you could just replace the Phar Lap stuff with a DOS stub and run it under Win32.
I think it is mentioned in the README that support ended with 6.12.I was wondering if the later 6.1x or 7.x would run with the Phar Lap stub. It's convenient when I'm running DOSEMU on *nix--I don't have to install a Win32 host.
Well, the Phar Lap extender dates back to 1993 and implements only a subset of Win32 APIs. I don't think it is likely.That's not my point--I wonder if sufficient back-compatibility with the Phar Lap extender was maintained to allow for adding it to 6.12+-7.10 and getting a product via a bit of binary hackery that will run under DOS without having to install the Windows API.
submit.py [email]email@example.com[/email] hello_bin.bin
The XT Server has received your file.
Your program is starting
Upload complete.
OK
Hello, World!
Program ended normally.
This concludes your XT server session.
#!/usr/bin/python
import sys, requests, re, signal
from HTMLParser import HTMLParser
debug = False
#Probably overkill for this...
"""def handler(signum, frame):
handler.cancel_vars = None
print 'User request to cancel process...', signum
if handler.cancel_vars is None:
print 'Nothing to cancel!'
else:
print 'Cancel ID is' + handler.cancel_string
#raise IOError("Couldn't open device!")"""
class MyHTMLParser(HTMLParser):
def __init__(self):
self.curr_tag = None
self.desired_tag = False
self.program_output = None
self.cancel_string = None
HTMLParser.__init__(self)
def feed(self, data):
HTMLParser.feed(self, data)
#return self.program_output.group(1)
def handle_starttag(self, tag, attrs):
self.curr_tag = tag
#if self.curr_tag in ['h1', 'p', 'pre']:
if self.curr_tag in ['p', 'pre', 'input']:
if debug:
print "Encountered desired tag:", tag
self.desired_tag = True
if self.curr_tag == 'input':
#handler.cancel_vars = attrs
if debug:
print 'PARSE-DEBUG: The Cancel ID comes from here...'
elif debug:
print "Encountered a start tag:", tag
def handle_endtag(self, tag):
if self.desired_tag:
if debug:
print "Encountered a desired end tag :", tag
elif debug:
print "Encountered an end tag :", tag
def handle_data(self, data):
if debug:
print "Encountered some desired data :", data
else:
if debug:
print repr(data)
else:
print data
if self.curr_tag == 'pre':
if debug:
print 'PARSE-DEBUG: This is where the XT output comes from...'
#http://stackoverflow.com/questions/3368969/find-string-between-two-substrings
#self.program_output = re.search('OK\n\t\t(.*)\n\t\tProgram ended', data)
elif debug:
print "Encountered some data :", data
def submit(email, binary):
# Set the signal handler and a 5-second alarm
#signal.signal(signal.SIGINT, handler)
data = """<!DOCTYPE html PUBLIC '-//W3C//DTD XHTML 1.0 Strict//EN' 'http://www.w3.org/TR/x
html1/DTD/xhtml1-strict.dtd'>
<html xmlns='http://www.w3.org/1999/xhtml' dir='ltr' lang='en-US'>
<head>
<meta http-equiv='Content-Type' content='text/html; charset=UTF-8' />
<title>XT Server - result</title>
</head>
<body><h1>XT Server</h1>
<p>The XT Server has received your file.</p>
<form action='http://reenigne.dyndns.org/cgi-bin/xtcancel.exe' method='post'>
<input type='hidden' name='secret' value='KLoRaPxQgzf_H5yl'/>
<button type='submit'>Cancel</button>
</form>
<pre>Your program is starting
Upload complete.
OK
Program ended normally.</pre>
<p>This concludes your XT server session.</p>
</body>
</html>"""
parser = MyHTMLParser()
email_data = {'email': email}
file_upload = {'binary': open(binary, 'rb')}
r = requests.post('http://reenigne.dyndns.org/cgi-bin/xtserver.exe', data=email_data, files=file_upload, stream=True)
for line in r.iter_lines():
#print line
#http://search.cpan.org/~gaas/HTTP-Message-6.06/lib/HTTP/Status.pm
#http://www.python-requests.org/en/latest/user/advanced/#streaming-requests
if (r.status_code < 200) and (r.status_code > 208):
#This doesn't get executed for some reason...
print 'Error: ' + r.status_code
print r.headers
print r.text.encode(sys.stdout.encoding, errors='replace')
break
else:
#print line.encode(sys.stdout.encoding, errors='replace')
parser.feed(line.encode(sys.stdout.encoding, errors='replace'))
if __name__ == '__main__':
if ('-h' in sys.argv) or len(sys.argv) != 3:
print 'Syntax: submit.py [email] [binary]'
else:
submit(sys.argv[1], sys.argv[2])
Here's a dirty little trick that I've grown accustomed to when making ROM images to burn:
Code:.model tiny,c ROM_PAGES equ 4 ROM_BYTES equ ROM_PAGES*512 video_seg segment at 0b800h video_seg ends .code code_start: dw 0AA55h db ROM_PAGES main proc mov ax, seg video_seg mov ds, ax mov si, 00h mov cx, 1000h mov ax, 0AA55h loop_vid: mov word ptr ds:[si], ax inc si inc si loop loop_vid int 3 main endp db (ROM_BYTES - ($-code_start) -32) dup (0) ; filler ; The following is entered with a G= in DEBUG. It computes and stores ; the checksum. It's always located 20h bytes before the end of the ROM. Checkit proc mov si,100h ; where files get loaded in DEBUG mov di,ROM_BYTES-1 xor ax,ax Check2: add al,cs:[si] inc si dec di jnz Check2 neg al mov cs:[si],al ; stores result in "Checksum" int 3 Checkit endp db (ROM_BYTES - ($-code_start) -1) dup (0) Checksum db 0 end
(Note that I've changed the segment to B800 and the length to 4K to give you a nice green screen. At any rate, run DEBUG on the .COM file and G=8E0 into the checksum routine. It'll compute and store the checksum and exit to DEBUG. Then issue a -W command to DEBUG and then a -Q. Presto--you have your checksummed image.
Well, remember that the area around address 500-5FF is used by BASIC, so it's probably safe to use for the debugger.
As far as memory size goes, you don't need to call INT 12H--just read location 00413-00414 for memory size in K.
