Gaming on the Tandy 1000 SX
Great Hierophant
Massachusetts, USA
The Tandy 1000 SX is a swell machine for pre-1990 PC gaming. However, there are some limitations on the machine:
1. Incompatibilities
Generally the only early games that will not work on a Tandy 1000 SX are those requiring BASIC in ROM and do not work with GWBASIC.
2. EGA & VGA
Some games (Commander Keen 1-6, Duke Nukem) do not support the Tandy Graphics Adapter and require a true EGA or VGA card to work. Fortunately, you can install one in this machine.
3. Raster Tricks
This machine has nearly perfect CGA compatibility, and as an added bonus, does not display "snow." Unfortunately, some games employ raster tricks that are timing critical and will not work correctly on the internal graphics adapter because of the speed. Jungle Hunt is one such game, the palette changes about 4 scanlines after it should. The rolling effect in Digger's high score screen is not right either.
4. Keyboard
The Tandy 1000s pre S/R/TL use their own keyboard with a custom layout. I have yet to encounter a game that would not work with it. If the discrete cursor keys do not work, then use the number pad keys just like on an IBM Model F keyboard.
5. Joysticks
Pre S/R/TLs do not allow you to disable your joystick ports, so you may need to find Tandy specific joysticks or build an adapter.
6. Mouse
Tandy 1000s, except for the TX and S/R/TLs, do not come with a serial port, so you will need to provide one or get a bus mouse and card.
7. Speed
The Tandy 1000 SX has two speeds, 4.77MHz and 7.16MHz. Even the fast speed will hardly allow you to play many games using a 320x200x16 resolution. There is an accelerator card called the 286 Express that can tame some of those games. However, it will only give you just under AT speeds. By contrast, a TX or TL/2/3 starts at AT speeds and can go up to respectable 386 speeds with an accelerator.
8. Expansion
The Tandy 1000 SX has five 8-bit ISA slots. Unfortunately, the case only allows for cards 10" long or less. The power supply only supplies 67W, which is low even for 8-bit machines. The -5v pin may not be active, which certain cards use.
9. Tandy Games
Many games that support the Tandy 1000 require a separate installation, so you would need the original disks to make it work.
10. Composite Color CGA Games
Many games that support the Tandy Graphics Adapter and the CGA will force you to use the TGA. If you want CGA RGB or composite, you will have to use another computer. The composite colors are different compared to the IBM PC CGA.
you might consider putting this in our wiki-there's some good information here, and I'd hate to see it get lost in the bowels of the forum after a couple months...
What games are those? I've never heard of any game that requires cassette BASIC to work.
2. EGA & VGA
VGA games generally run too slow on machines that are less than 10 Mhz, so you wouldn't really want to do that anyway.
3. Raster Tricks
You should be able to get these to work by setting the machine to 4.77 Mhz with the MODE SLOW command in Tandy DOS. For booter games, you can set slow mode by pressing F4 immediately after the POST beep.
It isn't just CGA games that have raster tricks. The PC port of Ghostbusters (which is PCjr/Tandy only) uses the 160x200x16 mode for the playfield, and the score counter at the bottom is in 320x200 resolution (probably 40-column text mode). On non-8088 Tandys, you have to switch to slow mode for the raster split to work properly.
Jungle Hunt does only work on real CGA. It just locks up on VGA, and DOSBox can't even run it. At least Digger runs on VGA (albeit with severely messed-up graphics).
4. Keyboard
Yes, the scancodes are different for some of the keys, although only those that aren't present on standard keyboards (eg. the cursor keys).
5. Joysticks
That is a problem, especially since the real Tandy sticks have sharp edges and are uncomfortable to use for any lengthy period.
6. Mouse
Instead of a serial port, the SX has...a light pen port, shared only with the original 1000. Trying to find the light pen for them is nearly impossible.
7. Speed
Depends. Games that were written in assembly language (most arcade titles) should be fine. You wouldn't want to try Sierra SCI games, though, or anything that says "8 Mhz or better" on the box.
8. Expansion
The missing -5V line is only a problem on original 1000s. It was corrected pretty quickly after Tandy discovered that a network card they were selling needed it.
9. Tandy Games
Debatable. Arcade games typically don't have a setup program and just ask you on startup what video mode you want to use. Lucasarts games don't have an install program either, or Sierra AGI games. SCI games do, and for those you would want an original copy (preferably a true original and not a compilation pack version). The same goes for strategy games, since they usually can't be played without a manual. Wolfpack (which I have an original of) has one with 90 pages (!)
Again, not a problem except possibly on the booter version of King's Quest 2. As I mentioned above, most games ask you what video mode you want, or if they do auto detect (as AGI and Lucasarts games do), they can be manually overridden.
The only exception might be Jumpman and certain Sierra booters like Troll's Tale that support the 160x200x16 mode, but check the BIOS ID byte to see if they're running on a PCjr. On Tandys, they only run in normal CGA mode. The above mentioned games support composite mode, so you can still get 16 colors, and since they use 640x200 composite graphics, it will look the same as on real CGA (the difference only applies to non-white colors). On the downside, you won't get the 3-voice sound.
There is one other limitation of the SX you left out: it can't have a full 768k of memory. Since some is stolen by the video, the most you can have is 576k.
According to the SX technical reference manual, the Tandy power-supply does not provide -5V. A 7905 voltage-converter can be found on the motherboard, but apparently only provides -5V to the printer interface, and not to the expansion slots.
Responses (I'm too lazy to quote)
1. See here:
http://www.mobygames.com/attribute/sheet/attributeId,112/
I know I read somewhere that Casino Games from IBM will not work with GWBASIC.
2. Probably not, but there are EGA games that will run tolerably.
3. The tricks I mention do not work correctly even in the slow mode.
Other than the aforementioned raster issues, Jungle Hunt plays just fine on the T1000, as does Digger.
4. Some key combinations are quite different on the Tandy as opposed to the IBM keyboard. But it is not that bad overall if you know your IBM PC Model F layout.
5. The boxy joystick was quite popular in the early days of PC gaming. I prefer to use a joystick with a full handle grip or a Gravis Gamepad if analog control is not required. The Tandy/PCjr. sticks are very good for breakout-type games because they allow you to switch between self-centering and floating.
6. Instead of a serial port, the SX has...a light pen port, shared only with the original 1000. Trying to find the light pen for them is nearly impossible.
Indeed! However, if you have a Tandy Deluxe Mouse, you will not need the serial port for a mouse because it plugs into a joystick port.
7. Early Lucasarts SCUMM games may be playable at that speed, as are most AGI games, but interepreter games are generally to be avoided.
8. This should be an easy fix, especially if there is a regulator somewhere on the board.
9. I have seen this with VGA games like Lemmings, Wing Commander, Dark Queen of Krynn and EGA games like Wasteland, Fountain of Dreams, Dragon Wars, Hard Nova. Also, Sierra and Lucasarts made seperate 16 and 256 color versions of many of their games, with the 16 color versions more difficult to find.
10. If an AGI game detects a Tandy, then it will not let you use any other graphics mode.
Another consideration. Actually, in DOS only 16K is taken (because it is using text mode) Graphics modes on the Tandy take up 32K, unless using multiple graphics pages (I don't know of any games that take thta much.) However DOS generally takes at least another 32K away from you, but this may not be true in every case.
I couldn't imagine why it wouldn't work, unless it uses the cassette port on the 5150 for some reason.
EGA games mostly all use the 320x200x16 mode, which is 32k just like the Tandy 320x200 mode. The VGA 320x200x256 mode is 64k and thus a bit too much for slower machines.
Digger just uses the normal CGA 320x200x4 mode, but sets it by writing directly to the registers, which is why it produces a scrambled mess on VGA. I don't know exactly why Jungle Hunt completely fails on VGA. Moon Patrol also locks up after about 5-7 seconds of play.
Well, you press Alt+Break or Hold instead of Scroll Lock. Some early Sierra games like Ulysses and the Golden Fleece use Scroll Lock.
True. I one saw a joystick that looked exactly like the Tandy ones, but with a standard 15-pin connector.
That's the mouse for the TRS-80 CoCo, correct? If it's read off of the joystick ports, then that means it only works with software that has joystick support.
As for light pens, if you could find a Tandy pen, at least it has an external port to connect to, as opposed to the IBM CGA card which requires you to run the cord inside the computer's case.
I've tried Maniac Mansion (low-res) on my 5150, and it's a little slow, but otherwise playable. BTW, the version included with DOTT does not work on 8088 machines (the Tandy support is messed up there as well). You need the original standalone version. Last Crusade and Monkey Island are too slow for anything under 8 Mhz.
As for Sierra games, all AGI should be fine on 8088s, but SCI is a no go. KQ4 on my 5150 is so slow that when you enter the dwarves' diamond mine, the music starts playing about 8 seconds before the graphics appear (!)
I've never played any of those games. I was thinking of Arkanoid, Bubble Bobble, and Double Dragon, all of which ask you on startup what graphics mode you want (BB saves your settings, the other two don't).
The enhanced versions of Lucasarts games are indeed easier to find than the originals, although that's not so much the case with Sierra games.
You can't force it into CGA mode by typing SIERRA -R or SIERRA -C?
Text, CGA, and 160x200 graphics use 16k, while the other two modes are 32k (64k for the 640x200x16 mode on later T1000s). The amount of memory DOS uses varies. DOS 3.30 occupies about 60k or so. DOS 5.0 and 6.x use even more. The Tandy video can in fact allocate as much as 256k of memory, although no software actually needs that much
I don't know why Casino Games will not work with GWBASIC, thats just what I read.
There are drivers that allow you to emulate a Microsoft mouse with the Deluxe Mouse, which does connect to the joystick ports. See here:
http://www.oldskool.org/guides/tvdog/utilities.html
You need a mouse driver anyway for DOS programs.
Some AGI version 3 games, like the Manhunters and KQ4, benefit from the fast 8088 of the SX. But these games will not be forced into using anything other than Tandy graphics and sound, even with -c and -r.
I think I've figured out the reason why. Casino Games probably manipulates BASIC's system variables, which can PEEKed and POKEd after typing DEF SEG without any segment name. On all versions of BASICA, the system variables are at the same location in BASIC's data segment. However, GWBASIC's variables are in different locations depending on what version it is.
That goes without saying.
I don't have a Tandy 1000, but I will have to try that with DOSBox and see.
The AGI KQ4 is not easy to find at all, since it was only available during the first printing of the game.
Perhaps there is a version of GWBASIC that has the variables in the same place as BASICA or can be made to put the variables in the same place.
DOSBox may not give you a true representation of how games that autodetect Tandy work. As an example, in Maniac Mansion and Zak McKracken, these games will autodetect Tandy sound even if the active video is not Tandy on real hardware. In DOSBox, you will not hear Tandy sound.
I have a BASIC book that lists all the system variables and their locations for BASICA, GWBASIC 2.11, and some for GWBASIC 3.20. Other versions might differ from those.
Ok, I tried KQ2 with DOSBox. You're right; it won't work in CGA mode on a Tandy.
Tandy 1000 Gaming issues or known problems?
Do not start:
- WinterGames/SummerGames CGA (com+dat-file)
- Xenon (TDY-Version)
- Defender (has no sounds)
- Speedball (has no sounds, has no floor)
Do not find:
- F16-Falcon (TDY-Version)
- Hostages (TDY-Version)
- North&South (TDY-Version)
- TestDrive1 (TDY-Version)
- DefenderOfTheCrown (TDY-Version)
Where can I get a replacement-floppy für my 1000RL ?
Thx
Doc
Winter-Games starts with a winter.com with about 2K bytes, if it is only around 400bytes it dos not start.
currently searching fur summer-games and world-games with the bigger *.com start file.
2. EGA & VGA
Old dead thread I know... Has anyone made any patches or TSR's that can run on a PCJR or TANDY 1000 to play these games.. Even if just CGA? I have my 1000TX working and just spent a half hour trying to get these exact games working to no avail. Im down to mostly just my Sierra games. Warlords wouldn't even load.
Just curious what may have been developed on these systems.
Also I have watched a few videos online and people have gotten Monkey island playing on Tandy 1000 systems. But my version only gives the option for MCGA, EGA, or VGA. And it will not even show anything with the MCGA switch. IS there another version?
FWIW, there’s a Tandy video mode patch for Commander Keen 4:
Re: Warlords, that’s a game from 1989 that seems pretty specifically aimed at EGA/VGA. I think you need to choose your battles with a 1000 TX: never forget it’s basically an IBM PCjr with a 286 upgrade, not a real AT.
Here’s a thread full of links to lists of Tandy 1000 enhanced software:
The TX is a top tier 1000 and should run almost all of beautifully. You just need to know its limits.
Oh i completely get you. But wasnt the TX sold until 1991 or 1992? Meaning it was still prime for warlords..?
Regardless i get what your saying. I was just hoping games that ran native cga would work. Specifically keen and monkey island.
I mean CIV 1 plays! 🙂
Nope. The TX was replaced by the TL in the 1989 catalog. The only “X” series to make it into the 90’s was the bottom-feeder HX, which embarrassingly were all sold off for pennies on the dollar in mid-1990 after it dawned on everyone that a 256K floppy only XT was unsellable in the real world.
As I mentioned in the other thread I legitimately consider the TX “peak Tandy 1000” because when it came out in 1987 there was still legitimately a niche for such an audaciously hacky creation. The L series aren’t objectively terrible computers judged on their own merits, but Tandy should have known the party was over by 1989.
I hope you dont mind me picking your brain about Tandy info. You clearly know these systems. I honestly havent done too much on them. I got into a bunch of PCjr repairs, Once I had them all fixed (sans one floppy controller) I never did too much with them expect for trying out the JrIDE from texelec.
Im still learning the ins and outs. Im running DOS 6.22 since I just like the features of it. I found the original System disk which is DOS 3.2 just for reference. And I have a disk of Deskmate II.
For some reason I cannot get DOSSHELL to work, it just loads a black screen. Do I need to modify the DOSSHELL.ini?
Also I tried out that Commander Keen 4 tandy. I made a copy of my working Commander Keen directory. I copied the new files into it and replaced the existing files. Here is the current file listing:
When I execute the new KEEN4E.exe I get this screen:
I would assume TANDY should be selected for Video and Sound but they clearly are not. All I can do is press a key. I am met with the next screen. Eventually the demo plays and I hear PC speaker audio.
Unfortunately I'm not going to be a lot of help for either of those questions. I don't use MS-DOS 6 (I'm running PC-DOS 7 myself, it's saves a couple K of memory), and I don't use the shell at all. I have vague memories that it's a known issue that the task switcher is broken on Tandy 1000s? (I guess it says so in the Tandy 1000 FAQ.) Maybe someone else has experience with it?
Re: Commander Keen, I'm in a somewhat unusual spot in that I *have* tried one of the Tandy patched builds, but only on my VGA-equipped "1000 SUX" (the Tandy HX motherboard with a stack of homemade hacks wedged into it.) I can verify that it works and and is able to play the music through the Tandy sound hardware, but of course because I have the VGA card it's using the EGA graphics. I guess I could try pulling the 1000 EX back out and seeing if it works correctly...
Actually, wait: did you download the correct ZIP file from the github site? For Tandy graphics you should have "KEEN4T.EXE" and "TGAGRAPH.CK4" files in your directory, and launch "KEEN4T", not KEEN4E.
You are right! I guess I didnt have the right files. I found them now.
When I run Keen4T I get this message.
I run it again with the hiddencard parameter. Strange, why is it telling me this when I have 128K of available video memory?
Anyway the github site mentions using the ADJMEM program before running KEEN4T so I downloaded it and tried it out.
I ran the game and I still get the error about improper video card. So I add a second alotment of 16KB and then run the game. It then works with -32 KB added
So the game loads Tandy graphics but the Tandy sound still wont load. It has the sound files right? Or did I miss those as well?
