Chuck(G)
25k Member
In the PC system of things, there is a card guide in back for full-length cards; anything shorter than that depends pretty much on the one screw and edge connector for support. Don't get me started on the lack of any sort of card extraction system to avoid chewing your fingers up on stubborn cards.
Had IBM adopted the NEC C-bus system (shared by many other buses) of a card that slides into a slot, things might have been different. Better airflow, no chewed-up fingers--and a bus that starts off as 16-bit.
There are other things to like about NEC 9801-family software, even with its superior graphics. Support for 4 floppy drives, right out of the box. The partitioning scheme for the hard disk allows for 16 single-level partitions--you can boot from any one of them. The BIOS started off by allowing booting from any floppy, hard disk, or MO drive...
And the one I like the best--the floppy format is exactly the same from 8" through 5.25" down to 3.5".
