gekaufman
Geoff Graham released an inexpensive video terminal design in 2014. As some may remember I organized a group purchase of PCB's and parts for construction.
Unfortunately the original design only had TTL serial output and it was necessary to add external drivers for RS232 levels.
Several others have updated the firmware including allowing use of a USB keyboard.
Here is an updated PC board that incorporates several changes:
RS232 driver is included (Max232CPE or equivalent)
Color selection is now thru jumpers.
USB connector changed to a USB "A" connector so a keyboard can be directly connected
Barrel Jack input for 5v added
Silk screening improved to show jumper settings.
The original firmware will support a PS/2 keyboard input
David Hansel's modified firmware will support a USB keyboard.
Enjoy!
BTW I have a pile of spare PC boards and can program PIC's for folks. Other parts are very easy to order thru Mouser or Digikey.
https://hackaday.io/project/173216-ascii-video-terminal
Enjoy!
