ElectroArc
Hello everyone,
I've been trying to create a bootable DOS diskette for my Morrow Pivot II, but nothing seems to work.
I've been trying to use these two images:
(Morrow Pivot DOS) https://winworldpc.com/download/13c2a959-c3b4-c2bf-c2b4-11c3a6c2bb2a
(Osborn 3 DOS) https://winworldpc.com/download/3648c39e-5856-5211-c3a4-c2a90f7054ef
Neither of them work for me though. Writing the disks results in unbootable images on both the windows 98 pc that made them and the Pivot II the images are intended for.
I don't understand what could be wrong here.
With Pivot DOS, when attempting to boot on the Windows 98 machine, the diskette will spin up, and then stop with an infinitely blinking cursor on screen. On the Pivot II, it states that the diskette is not bootable.
Osborn 3 DOS is is basically the same, other than the fact that the Pivot II will infinitely read it, spinning forever.
Does anyone know what I could be doing wrong here? I burned the Pivot DOS image using ImageDisk, which would make it an exact replica of the original diskette, which means it should work perfectly, correct? I also can't get WinImage 8.1 to work with the Osborn image, so I opted to just drag the files onto a formatted disk. WinImage seems to hate the 360k images I have, because all of them cause a page fault and make the application crash. I tried researching that issue, and nothing came up.
Also, does anyone happen to have their own image I could try? Any DOS variant for the Morrow Pivot, Osborn 3, or Zenith 171 should be virtually the same, as they're all the same computer.
Thanks for any help!
