alexkerhead
Just got me some new parts to build a new engine for the 83 silverado.
Pistons and rods - 0.030 over
Rod/crank sleeves
Large timing gear, Chane and small timing gear
Oil retriever
Crank sleeves
Oil pump
Piston rings
Complete gasket set
Reworked/seated valves
After I put the pistons in the right side
After I put three of the four pistons in the left side. I got lazy and went in and ate before I did the 4th
Picture of the crank with 7/8 pistons in.
Theres a bunch of other stuff I forgot to take images of.
I also baught a ring expandaer to put the rings on the pistons and a ring compresser to put them in the cylinder shafts.
I am borrowing a valve spring compressor tommorrow as well.
I should have it built soon.
Rod/crank sleeves
Oil retriever
Crank sleeves
Oil pump
Piston rings
Complete gasket set
