First, I commend you for getting it to work. As I mentioned in my post, I couldn't get it to work under DOS 6.22 and ROM 1.43.
What size was your GoTek drive 720 or 1.44 Floppy? Did you replace your 360 K Floppy or use it as B drive?
The following is what I got from the testing of the GoTek 72 (720) Floppy Emulator
(Note: Drive 0 on Emulator set as Boot Disk MSDOS 6.22)
Settings not tried "J5, JC, JB, MO"
[TABLE="border: 1, cellpadding: 1"]
[TR]
[TD]Jumper
Setting[/TD]
[TD]Drive
Emulated[/TD]
[TD]Floppy 360K
Present[/TD]
[TD]Machine
Response[/TD]
[/TR]
[TR]
[TD]JA & S0[/TD]
[TD]B[/TD]
[TD]Yes[/TD]
[TD]"Ready, ROM error"[/TD]
[/TR]
[TR]
[TD]JA & S1[/TD]
[TD]B[/TD]
[TD]Yes[/TD]
[TD]Not ready on A. ROM Basic not available. Press reset
(Note: Floppy A lamp lighted while emulator light out)[/TD]
[/TR]
[TR]
[TD]S0[/TD]
[TD]B[/TD]
[TD]Yes[/TD]
(Note: Both LED's on Floppy A and the emulator are lighted)[/TD]
[/TR]
[TR]
[TD]S1[/TD]
[TD]B[/TD]
[TD]Yes[/TD]
[/TR]
[TR]
[TD]JA & S0[/TD]
[TD]A[/TD]
[TD]No[/TD]
[TD]Not ready on A. Primary Boot Strap, flashing press restart to reboot." (Note: Emulator Lamp out before and after POST. LED thumb drive on for 1-3 sec used right button to load buffer before sequence of boot.0 shows buffer loaded from 0 also LED on thumb drive illuminated)[/TD]
[/TR]
[TR]
[TD]JA & S1[/TD]
[TD]A[/TD]
[TD]No[/TD]
[TD]"Ready on A. Primary Boot Strap, flashing press restart to reboot." (Note: Emulator Lamp out before POST, however, Emulator Lamp on after POST for 1 sec. LED thumb drive on for 1-3 sec used right button to load before sequence of boot. D0 shows buffer loaded from 0 also LED on thumb drive illuminated)[/TD]
[/TR]
[TR]
[TD]S0[/TD]
[TD]A[/TD]
[TD]No[/TD]
(Note: Emulator Lamp out before and after POST. LED thumb drive on for 1-3 sec used right button to load buffer before sequence of boot. D0 shows buffer loaded from 0 also LED on thumb drive illuminated)[/TD]
[/TR]
[TR]
[TD]S1[/TD]
[TD]A[/TD]
[TD]N0[/TD]
[TD]"Ready on A. Primary Boot Strap, flashing press restart to reboot." (Note: Emulator Lamp out before POST, however, Emulator Lamp on after POST for 1 sec. LED thumb drive on for 1-3 sec used right button to load buffer before sequence of boot. D0 shows buffer loaded from 0 also LED on thumb drive illuminated)[/TD]
[/TR]
[TR]
[TD] [/TD]
[TD] [/TD]
[TD] [/TD]
[TD] [/TD]
[/TR]
[TR]
[TD] [/TD]
[TD] [/TD]
[TD] [/TD]
[TD] [/TD]
[/TR]
[TR]
[TD] [/TD]
[TD] [/TD]
[TD] [/TD]
[TD] [/TD]
[/TR]
[TR]
[TD] [/TD]
[TD] [/TD]
[TD] [/TD]
[TD] [/TD]
[/TR]
[TR]
[TD] [/TD]
[TD] [/TD]
[TD] [/TD]
[TD] [/TD]
[/TR]
[TR]
[TD] [/TD]
[TD] [/TD]
[TD] [/TD]
[TD] [/TD]
[/TR]
[TR]
[TD] [/TD]
[TD] [/TD]
[TD] [/TD]
[TD] [/TD]
[/TR]
[TR]
[TD] [/TD]
[TD] [/TD]
[TD] [/TD]
[TD] [/TD]
[/TR]
[TR]
[TD] [/TD]
[TD] [/TD]
[TD] [/TD]
[TD] [/TD]
[/TR]
[TR]
[TD] [/TD]
[TD] [/TD]
[TD] [/TD]
[TD] [/TD]
[/TR]
[TR]
[TD] [/TD]
[TD] [/TD]
[TD] [/TD]
[TD] [/TD]
[/TR]
[/TABLE]
I didn't know about the Flash Floppy. I will have to look into it again and see if I could get it to work.Thanks for the info on Flash Floppy. Some how I would have to get beyond the POST and the startup of the MSDOS.
