glitch
By request, and because I too have a few that need replaced:
You bend up the legs on a DS12885 (the bare IC used inside the DS12887 module), glue my little board on top, and solder the leads down:
I had a little 486 ISA industrial SBC that needed a DS12887 replaced, so that was the test candidate:
Works fine! I need to tweak the castellated holes on the board a bit. There's not enough copper to hold the plated-through hole in, at least for OSH Park's castellation process. I'll release the files once it's ironed out. But, it works, and it'll be easier for hobbyists to assemble than the version that uses surface mount bits. I believe it's cheaper as well -- the DS12885 is cheaper than the surface mount version, and you don't need to acquire module pins since the DIP takes care of that.
I'll probably do a run of panelized modules and make up a bunch of these, so if people want a fully assembled, ready-to-go version, that's coming.
One of the best aspects (aside from never having to rework it again!) is that all of the parts are current production and available from e.g. Mouser. No need to have an old IC and tear it down, as with the 48T02/48T08!
