aesis
Hi guys, thanks for the opportunity to ask for help in this forum!
I have a pretty serious problem, I have a PC XT ... 1989, 8088 MHz, 640 RAM, CGA video, MS-DOS 3.3
Unfortunately, it often happened that after power is blocked until the last period that started only with the floppy system,
after putting the dos I walked into C: \ and the hard working normally, I discovered that the problem was the IO.SYS files and managed to replace it ...
I understood that the disk has bad clusters and I used CHKDSK but unfortunately changed my files and folders of replacing disk
with called FILE0001 FILE0002 FILE0003..to file FILE0106, also replaced me the SYSTEM folder with all the files within it,
I deleted these files thinking they can re-install MS-DOS 3.30, but this too hangs after installing autoexec.bat..
I decided to format the floppy by Formac C: But immediately after the command hangs at 3% and tells me:
Can not format the drive, disk unusable
I thought about using FDISK, but I'm afraid that after deleting the partition I no longer use the hard!!
Now I do not know what to do and I ask you why you most likely have more experience in the field and before making an irremediable mistake ask advice.
The record is a MINISCRIBE 8425
Thanks for your time!!!
P.S:Sorry for my English.
