hi folks. just found this site and i happen to have a 1993 canon innova 486e model 25/120 desktop that a friend gave me years ago. it has a modified acer v6 motherboard {mine only has 3 simm slots vs 4 that all info i found says} so i pulled it out and it still booted but bad chksum. onboard battery still had power but one pin was corroded and soldered battery broke off. luckey it had ext bat connecters so no problem. upgraded cpu from 486sx @ 25mhz to 486dx2 @66mhz , original conner hdd 120mb to two newer drives { i just set chs to max for both as bios only goes to 504mb then fdisk,format fat16}, added a network card , added sb16 with ide for cd {only one onboard ide} added 36mb ram + 4mb onboard for 40mb total .
i loaded dos 6.22+win3.11 , loaded drivers , everything works like a dream, even go on the internet! my problem is i noticed that emm386 was not loaded and when i try {different trys at config} i keep getting one of three errors , #12, #3, #1 . so will i just have to go without network { at the net initialize is where i get errors} to use emm386? what little dos i know {could make simple boot disk with mouse is about where i`m at} doesn`t solve my problem. i enjoy breathing new life in to old computers { this is oldest that works} and just wish to have a real dos/win3.11 machine. i`m thinking it is software {memory,stacks, files?????} but i don`t quite understand enough about how to tweak config and autoexec.
thanks for any education!!
