Has anyone a XXDP image with TU60 driver?
MattisLind
Stockholm, Sweden
I am trying to create a TADP image to run with my TU60 connected to an 11/10 (to act as a loader for SPCWAR.LDA file). But I cannot find any XXDP image which has the CT driver. Malcom has cassettes listed on his webpage which looks like they might contain a TADP but I am not sure if they ever were dumped. Anyone know of a XXDP image which contain a CT / TA11 / TU60 driver?
I have seen a TADP.BIN file on one image but haven't figured out how to make a bootable TU60 image from just the binary using PIP in RT11. I assume that the LOAD / SAVE combination in UPD2 program of XXDP does a bit more than just copy the file. Is there a way of doing the same thing in RT-11 or perhaps DOS-11?
XXDP-Plus_D0_DL.DSK
  731  RMDP  .BIN      29-DEC-77         17    035100
  732  RKDP  .BIN      29-DEC-77         17    035121
  733  TCDP  .BIN      13-AUG-76         17    035142
  734  TMDP  .BIN      29-DEC-77         17    035163
  735  THDP  .BIN      29-DEC-77         17    035204
  736  RXDP  .BIN      29-DEC-77         17    035225
  737  RBDP  .BIN      13-AUG-76         17    035246
  738  RPDP  .BIN      16-AUG-76         17    035267
  739  RSDP  .BIN      13-AUG-76         17    035310
  740  TADP  .BIN      13-AUG-76         17    035331
  741  RLDP  .BIN      29-DEC-77         17    035352
  742  RRDP  .BIN      23-MAY-80         17    035373
  743  RYDP  .BIN       2-AUG-78         17    035414
Yes. Seen that. But if I boot that image I can not make it to save to the TU60 using UPD2. Do you know how to create a TADP cassette using that RK image as a basis?
Here is when I tried to do exactly that using the XXDP image you are referring to. Also tried a XXDP+ image with similar results. But it comes to my mind that it might be possible to use CILUS under DOS-11. CILUS is used to write a bootable image library for RSTS-11 and DOS-11. Perhaps it can do the same with XXDP? DOS-11 and XXDP filesystems are mostly identical so a DOS-11 system should be able to read a XXDP disk.
sim> b rk0
DZQUD-E 21-JUL-76 RKDP - XXDP RK11 MONITOR 28K
RESTART ADDR:152522
BOOTED VIA UNIT#: 0
TO ABORT THE FOLLOWING HELP MESSAGE TYPE CTRL C (^C)
TYPE:
F<CR> TO SET CONSOLE FILL COUNT
D<CR> FOR DIRECTORY ON CONSOLE, OR
D/F<CR> FOR SHORT DIRECTORY ON CONSOLE, OR
D/L<CR> FOR DIRECTORY ON LINE PRINTER, OR
D/L/F<CR> FOR SHORT DIRECTORY ON LINE PRINTER,
R COPY<CR> TO RUN COPY PROGRAM,
R FILENAME<CR> TO RUN ANY OTHER PROGRAM.
L FILENAME<CR> TO LOAD A PROGRAM ONLY
S<CR> TO START THE PROGRAM JUST LOADED,
S ADDR<CR> TO START THE PROGRAM AT SPECIFIC ADDRESS
C FILENAME<CR> TO RUN A CHAIN,
C FILENAME/QV<CR> TO RUN A CHAIN IN QUICK VERIFY MODE.
REFER TO XXDP USER MANUAL MD-11-DZQXA FOR ADDITIONAL HELP.
.D
ENTRY# FILNAM.EXT DATE LENGTH START
000001 THDP .SAV 29-MAR-77C 16 000105
000002 TMDP .SAV 29-MAR-77C 16 000125
000003 RBDP .BIN 29-MAR-77 17 000145
000004 RKDP .BIN 29-MAR-77 17 000146
000005 RMDP .BIN 29-MAR-77 17 000147
000006 RPDP .BIN 29-MAR-77 17 000150
000007 RSDP .BIN 29-MAR-77 17 000151
000010 RXDP .BIN 29-MAR-77 17 000272
000011 TADP .BIN 29-MAR-77 17 000273
000012 TCDP .BIN 29-MAR-77 17 000274
000013 THDP .BIN 29-MAR-77 17 000275
000014 TMDP .BIN 29-MAR-77 17 000276
000015 UPD1 .BIN 29-MAR-77 17 000417
000016 UPD2 .BIN 29-MAR-77 30 000420
000017 COPY .BIN 29-MAR-77 27 000421
000020 HELP .TXT 29-MAR-77 22 000422
000021 XTECO .BIN 29-MAR-77 26 000423
000022 RKHEAD.BIN 5-OCT-77 19 000544
000023 SIZER .BIN 29-MAR-77 18 000600
000024 ACT .BIN 29-MAR-77 32 000625
000025 ACTS01.TXT 29-MAR-77 4 000630
000026 ACTS05.TXT 29-MAR-77 5 000646
000027 ACTS06.TXT 29-MAR-77 7 000654
000030 ACTS07.TXT 29-MAR-77 7 000677
000031 ZLABA1.BIC 29-MAR-77 15 000717
000032 ZLADC0.BIN 29-MAR-77 17 000732
000033 ZLACC0.BIN 11-AUG-76 16 000742
000034 ZLKAA0.BIC 29-MAR-77 12 001032
000035 ZLAEA0.BIN 11-AUG-76 13 001057
000036 ZLCAC0.BIN 11-AUG-76 11 001062
000037 ZLPAB0.BIN 29-MAR-77 9 001065
000040 ZLPBB0.BIN 29-MAR-77 9 001126
.R UPD2
DZQUB-I 21-JUL-76 - XXDP UPDATE PROGRAM #2
DATE: 21-JUL-76
21-JUL-76
PROGRAM RELOCATED TO: 120764
RESTART: 125116
*ZERO CT0:
OUT DEVERR
Simulation stopped, PC: 126534 (TSTB @122734)
sim> attach rk1.dsk
RK: creating new file
sim> c
*ZERO DK1:
*LOAD DK0:RKDP.BIN
XFR:000001 CORE:000000,020000
*SAVM DK1:
I can offer you my original XXDP tape from my DEC Service times
I think I created this in 1978 and it booted to XXDP and contained some diags
I never used it again and it was stored since in a dry environment
No clue if it would still work, but I can send it to you in Sweden if you like
(I am in Austria)
Partial success :)
RESTART ADDR:152522
BOOTED VIA UNIT#:  0
TYPE:
.R UPD2
DATE: 26-JAN-99
26-JAN-99
RESTART: 125116
*ZERO CT0:
*LOAD DK0:TADP.BIN
*SAVE CT0:TADP.BIN
OUT DEVERR
*DIR CT0:
26-JAN-99
000001  TADP  .BIN      26-JAN-99C
DZQUE-F 21-JUL-76 TADP - XXDP TA11 MONITOR 28K
RESTART ADDR:152276
BOOTED VIA UNIT#:  0
TYPE:
E 0<CR> TO OPERATE OFF DRIVE 0,
E 1<CR> TO OPERATE OFF DRIVE 1.
Much better :)
Connected to the PDP-11 simulator CON-TELNET device
RESTART ADDR:152522
BOOTED VIA UNIT#:  0
TYPE:
.R UPD2
DATE: 27-JUN-99
27-JUN-99
RESTART: 125116
*ZERO CT0:
*LOAD DK0:TADP.BIN
*SAVE CT0:TADP.BIN
*FILE CT0:=DK0:UPD2.BIN
*FILE CT0:=DK0:ZTAA??.*
ZTAAC0.BIN
*DIR CT0:
27-JUN-99
000001  TADP  .BIN      27-JUN-99C
000002  UPD2  .BIN      16-AUG-76
000003  ZTAAC0.BIN      11-AUG-76
*BOOT CT0:
RESTART ADDR:152276
BOOTED VIA UNIT#:  0
TYPE:
.R UPD2
DATE: 27-JUN-99
27-JUN-99
RESTART: 125116
*DIR CT0:
27-JUN-99
CAPS-11 V01-02
.DATE 27-JUN-99
.VER
CAPS-11 V01-02
 27-JUN-99
.DIR CT0:
 27-JUN-99
CTLOAD SYS 08-AUG-73
CAPS11 S8K 09-AUG-73
PIP    SRU 09-AUG-73
EDIT   SLG 09-AUG-73
LINK   SRU 09-AUG-73
ODT    SLG 09-AUG-73
PAL    SRU 09-AUG-73
DEMO   PAL 09-AUG-73
.ZERO CT1:
.RU PIP
*CT1:=CT0:
*^C
.DIR CT1:
 27-JUN-99
PIP    SRU 09-AUG-73
EDIT   SLG 09-AUG-73
LINK   SRU 09-AUG-73
ODT    SLG 09-AUG-73
PAL    SRU 09-AUG-73
DEMO   PAL 09-AUG-73
Fantastic work!
Is there a PR towards SimH somewhere? I really would like to try this!
Is CAPS-11 able to read/write TADP-tapes?
I think I remember that RT-11 v4 could read and write CAPS-11 tapes.
I need to somehow get in touch with Bob Supnik in order to send the modified module.
In the meantime, I can post it on my file sharing site. The program I have compiled works under Windows.
XXDP and CAPS-11 on cassettes (surprise!) have the same file system, so in theory they should be read in both directions. Tomorrow night I'll try to see if RT-11 knows her.
But format of DATE is different...
CAPS-11 V01-02
.DIR CT1:
TADP   BIN --
UPD2   BIN --
ZTAAC0 BIN --
RESTART ADDR:152276
BOOTED VIA UNIT#:  0
TYPE:
.R UPD2
DATE: 28-JUN-99
28-JUN-99
RESTART: 125116
*DIR CT1:
28-JUN-99
000001  CTLOAD.SYS      18CmlW84
000002  CAPS11.S8K      18CmlW84
000003  PIP   .SRU      18CmlW84
000004  EDIT  .SLG      18CmlW84
000005  LINK  .SRU      18CmlW84
000006  ODT   .SLG      18CmlW84
000007  PAL   .SRU      18CmlW84
000010  DEMO  .PAL      18CmlW84
000011  EMO  .PAL      18CmlW84IN DEVERR
