skate323k137
I recently ordered some cartridge PCB's for my SC-3000 from PCBWay. It's a community design, and the designer has it set to not allow gerber downloads. As such you have to order it thru PCBway (not a big deal, the designer gets a cut). When I ordered it the 1st time, I approved removing the solder mask from the edge connector (the original designer had left solder mask between the fingers, and they recommended against this). The HASL ones I ordered came out fine:
Happy with those, and having built a couple, I put in an order for a not-insignificant amount of ENIG finished ones. I made the same approval regarding the solder mask between the fingers (Since I can't obtain the gerber to modify it), but these showed up with a defect of some concern:
Notice there's exposed ground plane right by the first pin, which is unfortunately +5v
I know the odds of these being put into a socket far enough (and askew enough) to cause a power-to-ground short there aren't great, but none the less, I'm not super settled about it. I wouldn't feel right selling them, honestly. I am open to input if I am over-reacting, it is just my gut feeling. Would you care? Be worried? Meh?
