QuantumII
Hi all,
I've just had some time to test the heathkit haul.
What I've discovered so far is:
- The Dual 8" Floppy drive powers up nicely and spins the disks.
- The H11 also seems to work, but I cannot get a console output on the H89 (More on this below)
- The H89 is actually a H19 which was converted to a H89 All-in-one computer. It is supposed to boot to a "H:" prompt, but all it does it giving me a flashing cursor, and I can type stuff to the screen.
I think the computer part of the H89 is connected to the terminal part of the H89 internally (What the previous owner told me), and the computer board does not boot for whatever reason (Bad connections or something)
With the custom serial cable that came with the H11, should I be able to connect the H11 to a PC running Procom or similar terminal emulator ?
Also, Where am I supposed to connect the 8" floppy drive to ? A connector inside the H11 I suppose ?
I have all documentation for all of this equipment, but it will take ages to go trough everything.
