VinnyVideo
I have an old Tandy 1000 RLX computer with a Seagate ST-351 A/X hard drive (the kind with an 18-pin jumper block and a four-pin power connector). I'd like to back up everything on the old Tandy, as there's some interesting (though not extremely important) data on it, and I'd like to be able to run some of its old programs with Tandem or Dosbox.
The problem is the 3.5-inch floppy drive is broken, so I can't back up using that, and I'm having trouble figuring out how to connect the hard drive (as a slave) to a modern (Windows XP or 98) PC. This is an operation I've done before, and while I've read the manual, the jumper configuration is pretty confusing. I know the drive is supposed to use IDE-AT mode when not attached to a Tandy, but a lot of the information I've seen Googling around contradicts other information, and I've heard you can fry this drive's data if you're not careful.
Is this the right jumper configuration for my purposes?
18 16 14 12 10 8 6 4 2
17 15 13 11 9 7 5 3 1
Alternatively, is there a way to copy the data by connecting the Tandy to a modern computer using a parallel or serial port? Any help would be greatly appreciated.
