framer
Does this card require an EGA monitor? I should select a mono card setting on the motherboard?
Thanks
framer
Thanks
framer
...unless the VGA monitor in question is a modern LCD with a composite or Y/C input port. Then they usually do sync below 24KHz (to 15.7KHz obviously).
It seems to me that one of our regulars offered a Sony 1302 a few months back with no takers. The old multisync/multiscan monitors shouldn't be that rare. Look for NEC, Sony and Mitsubishi in particular, get the model number and check the specs.
