modem7
10k Member
You missed the post prior to yours. The issue was resolved.To remove a non-dos partition from that drive using FDISK you will need to use a version of DOS greater than 4.01. As someone else mentioned, wiping the Master Boot Record might help (usage: a:\> fdisk /mbr ).
deathshadow wrote the same thing in a different thread, but when I FDISK/FORMAT'ed an ST-225 using IBM DOS 2.1, the DIR command output included, "21241856 bytes free".(and couldn't have a partition size bigger than 16MB).
johnnydicamillo: Did you see the same?
