Hp 9000 340
robbo007
Iberian Peninsula
Hi guys,
I've got a HP 9000 340 which has the Mechanical Engineering Series 10 software installed also it has the HP 46088A table. I don't have any connectors for the HP 46088A not sure what its missing. Also does this act as a license dongle for the software as I get an error when loading the software and it looks like it looking for a license dongle or something.
Cheers,
That is a HP-HIL port. Those cables are not easy to find.
However, I don't think the digitizer had ID module functionality (that's the "dongle" you might be referring to). Those also connect via HP-HIL. Unfortunately it probably wants a *specific* ID module.
I had an HP 360 that had an ID module, but I eventually removed it from the HP-HIL chain and it did not seem to have any effect with the software that I had installed (I only had a keyboard on the chain). I never understood how the ID modules were 'linked' to the software/hardware that required it, since when I was supporting HP servers, it was just a few years later and all we needed was the software and the codewords. Did you ever get this sorted?
The ME10 software uses the an ID module box connected to the HP-HIL bus. this module has a unique serial number which can be queried by the software.
It is possible to copy the ROM into another EPROM to duplicate such a module (the EPROM is soldered in and must be de-soldered first).
ID-modules can be found easily - should not cost more than 10$ or so.
This means you need the software AND the matching UID-Module.
The alternative would be to modify the ME10 software, of course - I have not seen such an adapted copy, though.
